Author Topic: looking for a quiet 3" muffler to use on a turbo car. School me......  (Read 25237 times)
So I'm getting ready to put the exhaust on the teg. I ordered a cheap 3" eBay n1 setup that has a resonator and a 3" fan boi canister muffler that I absolutely hate the look of. So I also have a huge resonator that I'm gona weld in behind the resonator that's already on there. Now I need a 3" muffler that is quiet, but not gona kill my flow. Also looking to make 4-500whp through this so it has to flow well. What call nigger suggest? I have enough room back where the muffler sits to fit a 20" long muffler.
Re: looking for a quiet 3" muffler to use on a turbo car. School me......
« Reply #1 on: March 05, 2012, 08:27:48 PM »
magnaflow round resenator and oval muffler has never failed me. The flow cannot be beat.
« Reply #2 on: March 05, 2012, 09:28:27 PM »
How loud is it though? Anything should be quieter than the 2.5 with no resonator and na, that's on there now.
« Reply #3 on: March 05, 2012, 09:36:23 PM »
3" turbo-back with 1 resonator ending before the axle is quieter than a stock civic exhaust w/fartcan. With a straight-through muffler you'll still get an annoying highway drone.
If you want QUIET, get a stock muffler from a higher-hp single muffler car. STI/WRX, supra, etc.
JaredKaragen
« Reply #4 on: March 05, 2012, 09:44:02 PM »
Folgers makes a great 6"...
« Reply #5 on: March 05, 2012, 10:08:57 PM »
Stock with a dump
« Reply #6 on: March 05, 2012, 10:18:27 PM »
Summit 3" turbo muffler.  Doesn't flow all that great but it's quiet.
« Reply #7 on: March 05, 2012, 10:53:07 PM »
Vibrant flat black.
« Reply #8 on: March 05, 2012, 11:40:28 PM »
Stock, weld in a levered bypass, call it a day  :noel:
imburne
    • TurboByHOLSET
« Reply #9 on: March 06, 2012, 12:35:38 AM »
Oval style can
« Reply #10 on: March 06, 2012, 12:43:48 AM »
You're overthinking this whole exhaust thing.
qft
i have had that exhaust on a DC, and im telling its fine out the box from china. i have the same one cut up and on my VR4, minus the N1, plus a Magnaflow. and its a little quiter. looks better forsure.
you arent gonna have much room for any resinator with the way that shit is setup. unless its part of the downpipe/cat area.
DasPoop
« Reply #11 on: March 06, 2012, 01:05:10 AM »
make sure its a good resonator in this spot otherwise it will quickly lose its function and be shooting red how chunks of fiberglass at the people behind you.
« Reply #12 on: March 06, 2012, 01:25:03 AM »
I haven't opened the box yet, but I'm gona cut the exhaust right b4 the bend in front of the gas tank and add it in between there and the back of the resonator that came with it. If I have to move the China resonator around I will. I just want it pretty quiet.
slappynuts
« Reply #13 on: March 06, 2012, 05:24:50 AM »
I have heard every type of muffler and exhaust (or lack of) on the hondas and the only ones I recommend are the vibrant flat black one and the magnaflow. I have magnaflow on my car and that is what we usually use on everything.
SQ is the SQUAD
« Reply #14 on: March 06, 2012, 11:38:21 AM »
i use all magnaflow cat, glasspack resignator and muffler.
« Reply #15 on: March 06, 2012, 11:42:21 AM »
All that is usually too expensive for me.  :noel:
« Reply #16 on: March 06, 2012, 12:10:59 PM »
Well I'm pretty sure that the resonator that I'm adding is a re branded magnaflow. It's a ss unit that is from a Injen 3" exhaust for a srt4. I snaged it from my bro in law a few years back. It's what I ran on the crx. But it was just that and 3" straight pups and it was fucking loud. I'm looking to quiet it down. So I hope what ever muffler I add helps.
« Reply #17 on: March 06, 2012, 02:12:53 PM »
3" turbo muffler are pretty quiet. i had one on my integra, cheap too like 30 bucks
DasPoop
« Reply #18 on: March 06, 2012, 02:29:39 PM »
Till that holset spools up and it opens up like a bag of popcorn. Not to mention the 1000rpm of spool you will lose
« Reply #19 on: March 06, 2012, 06:01:22 PM »
it really didn't have that much of an effect on my car.
you will always have more lag with any muffler on a turbo car, a chambered one will obviously be more. but you can't have a straight through muffler and have it be quiet
JaredKaragen
« Reply #20 on: March 06, 2012, 08:21:01 PM »
The exact reason Honda put a trunk release lever in the car :)
« Reply #21 on: March 07, 2012, 12:22:42 PM »
Yeah, pulling on a trunk release  cable and driving one handed while my Holset is @ 30lbs in 4th gear in the hwy sounds like it deserves the Darwin award.
It's was sketchy enough tuning with Dave in the crx in 4th gear on some back hillbilly farm roads with way shorter gears.
« Reply #22 on: March 07, 2012, 02:25:48 PM »
$10 fuel stop cable from tractor supply
« Reply #23 on: March 07, 2012, 03:53:05 PM »
If I do end up doing a cut out, (which I probably won't) ill use a eBay 60mm wastegate and hook a boost controller up to it so I can set where it opens up. I know it will probably never fail due to heat or anything of that nature. If it does fail it will be because of cdmness
DasPoop
« Reply #24 on: March 08, 2012, 11:42:08 AM »
What if you were to build something that would just bypass the muffler and bleed off excess backpressure? mechanical and repeatable then it doesn't matter what muffler you use. I would think that even a 38-40mm WG would work in this case.
« Reply #25 on: March 08, 2012, 01:15:54 PM »
Well I've been thinking about doing something like that. I can get a 60mm wastegate for under $70. And I can't get any muffler that's worth a Damn for that price. So I'm thinking about going that route and doing something of that nature over the rear axle b4 the muffler.
« Reply #26 on: March 08, 2012, 06:31:30 PM »
you've heard my car. no cat. 3" summit res and a 3" magniflow nice and quiet
« Reply #27 on: March 08, 2012, 06:34:38 PM »
Fuck, I'm lucky if I even remember what I had for lunch. No I don't remember how loud your car was.
boosted wagon
« Reply #28 on: March 08, 2012, 08:51:04 PM »
Vibrant flat black.
End this thread here. Best choice.
DasPoop
« Reply #29 on: March 08, 2012, 08:52:37 PM »
i just remember it was the most hardcore turbo setup there next to russes s/c
