Author Topic: does anyone bother leaving the stock o2 sensor in the downpipe?  (Read 12706 times)
lm getting my eg tuned next week, should i put a stock o2 in it or just leave the pigtail empty? Ive always had one before but do i need it?
Re: does anyone bother leaving the stock o2 sensor in the downpipe?
« Reply #1 on: March 19, 2012, 12:03:08 PM »
Do you have a wb permanently mounted in the car? And what ems?
« Reply #2 on: March 19, 2012, 12:05:48 PM »
chipped p28
aem pos wideband permanent mount
« Reply #3 on: March 19, 2012, 01:05:09 PM »
there isn't even a o2 plug on the crx harness... don't think the ITR ever had a stock o2.
« Reply #4 on: March 19, 2012, 01:22:53 PM »
Just you don't need your stock o2 in there then.
« Reply #5 on: March 19, 2012, 01:25:34 PM »
You don't need it, but if you have a spare hole it should be filled. If it's just the plug, you're best off putting a chopped plug into it (wires cut deep or removed). I've seen some unusual issues with a tiny handful of cars where it would toss a CEL code for O2, except O2 was removed and heater/O2 disabled.
« Reply #6 on: March 19, 2012, 04:02:59 PM »
Thats why I asked what ems. Ive seen crome freak out without a o2. Even with all that disabled. But that was years ago. Im sure they probably fixed bug that by now  ::)
« Reply #7 on: March 19, 2012, 04:05:41 PM »
And just a fyi, Leed once told me that for the most accurate reading your wideband should be about 10x the diameter of you pipe away in distance from your turbo.
2" down pipe 20" away from turbo
3" down pipe 30" away from turbo.
« Reply #8 on: March 19, 2012, 05:52:14 PM »
i have always used Innovate's rule of 18" or more from the turbo. i like to have a stock o2 in cars when i tune them. turn it off, make power, then turn it back on and tune the cruise for best mpg. a car will drive perfectly fine without it, but i prefer it there
« Reply #9 on: March 19, 2012, 06:20:28 PM »
So what do u keep the correction factor at for the stock o2?
« Reply #10 on: March 19, 2012, 08:23:04 PM »
So the answer is, you dont need one but you might lol, I think he has it on crome.
« Reply #11 on: March 19, 2012, 08:28:55 PM »
i have always gotten a cel with crome when there was no sensor present. the car runs perfectly fine without it. you can make your own decision with that info
DasPoop
« Reply #12 on: March 20, 2012, 01:57:01 PM »
Just leave it crome goes open loop above atmosphere.
