Author Topic: New Honda Cams, GSC Turbo Cams Vs 01 ITR Cams... Better spool and 30whp+ Gain..  (Read 13752 times)
gringotegra
  • Smoking Bisimoto's Builds, 1 Car At A Time
  • BISIMOTO KILLER!!!!!!!
We use GSC Power-Division cams in all of our Evo/DSM builds and have had amazing results with them. When Greg said he made a Honda cam and needed someone to test them i decided to try them out. It is a little scary throwing something untested in your car lol..
My setup:
Sleeved 84mm GSR
10.5:1 JE pistons
Eagle rods
Supertech Valve springs/Retainers
Ferrea 6000 IN/EX valves
Ferrea Keepers
B16 head
GSC Power-Division Turbo Cams
Victor X intake mani
Stock TB
FIC 2150's
E100 fuel
Stock sumped fuel tank
Twin 255's inline
ETS Forward Facing Turbo manifold
ETS 4x12x24" intercooler
Precision 6262, T3 .82A/R
This was a wastegate vs wastegate pull right about 11.5psi on the log:
Ill let the results speak for themselves..
Before someone says anything about the VTEC crossover, we fixed that later on lol...
The was pretty much as back to back as we could do.
I did not degree the cam's in, but we did mess with the cam gears a bit and no gain was made...
All and all it was worth some spool and about 30-40whp in some areas. And you don't have to degree them in!
Specs on the cams:
High lobe (IN/EX)
288/276 Duration
260/254@1mm Duration
12mm/11.5mm Peak valve lift
109/115 Center line
Video of said cams in my car @ Idle
http://www.facebook.com/video/video.php?v=10150726479604113#
Need some rippers!
bouncinofftherevlimiter
A friend of mine runs the GSC in his STI, heard really good things about them...
Like you said, they are pretty big in the 4G63 world too...
Nice to see they are a good piece
No longer own a turbo car...
HX35 18lb 486hp/391tq
What's the price on these bad boys gona be?
gringotegra
Forgot i had my 689whp dyno on video:
http://www.facebook.com/video/video.php?v=10150715995369113#
Retail price for the cams are $522.. Call me at the shop and i will give you a better deal!
That thing looks badass!
PRetty legit.. Speccally for TRULY drop in cams.
Good deal nigger
So u dropped them in and did no tuning and got these numbers?
Tell them to make a SOHC (D or ... F)
gringotegra
No timing or boost was added, this was straight wastegate vs wastegate... It even made these numbers at a half a point richer on E98
