Pages: 1 2 [3]   Go Down
Author Topic: Hi. Dyno sheets and vid on page 2!!  (Read 41881 times)
Re: Hi. Dyno sheets and vid on page 2!!
« Reply #60 on: July 02, 2012, 12:28:46 AM »
im on a single walbro 255lph intank on 880s, seems to do good.    Im running bpr7es plugs, so 2 steps colder from stock.  Do you know what the specs are on both cams?  I run a gude 252 duration intake/exhaust and .434 lift...
Can't forget I'm e85, and might go to e98 for consistency.
bisis gets all his springs from isky if you want to save 50 bucks on them
So does bisi do anything in house???
Dyno and he says in a vid he has his headers made inhouse.  :?:
gfrg88
  • 2.0Si-T
    • Classic Prelude
« Reply #61 on: July 07, 2012, 07:55:23 PM »
Ah I see! That explains why they crack!
86 lude on steriods.
gfrg88
  • 2.0Si-T
    • Classic Prelude
« Reply #62 on: October 25, 2012, 06:07:26 PM »
Couple of pics to keep the thread alive...
Redid the return bung on pan..
Welded inside and out. Shitty welds by a buddy of mine  :noel:
Got this yesterday.
Don't have pics of the disk since it's in storage but it's this exact one
Large blue!!!!!  O0
And a new shiny valve seat for the wastegate
More pics coming in next couple of weeks.. Money is tight, so I'm slowly buying the parts needed, but it's coming along   :noel:
gfrg88
  • 2.0Si-T
    • Classic Prelude
« Reply #63 on: January 27, 2013, 09:44:21 PM »
Shit's almost done, fuckers!!!!  :mexi:
I found some specs on my turbo finally-
17cm2
Compressor inducer 65mm, exducer 74 mm, 44 trim
Turbine inducer 50 mm, exducer 75 mm, 77 trim
So it's not too big, I also found two of the exhaust studs on the old head were stripped, and I was missing one nut. That's what was causing so much lag, and boost not coming in so hard. My turbo wasn't spooling fully. Go figure, still made almost 250whp :noel:
« Reply #64 on: January 28, 2013, 10:34:06 AM »
About damn time, DO WORK!
Pages: 1 2 [3]   Go Up
