Author Topic: how to check for ground loops problems  (Read 13785 times)
walter
« on: April 26, 2012, 05:49:56 PM »
Hi, i think i could be have problems with ground loops, i fried 2 ecus already , i dont know how but after works good, get CEL. tried a stock ecu and not cel and looks ok, i will chip it but i dont want to damage this other one....
Re: how to check for ground loops problems
« Reply #1 on: April 26, 2012, 05:52:50 PM »
What code is it throwing a cel for?
walter
« Reply #2 on: April 26, 2012, 06:08:23 PM »
it's solid Cel once key is on, as a fried ecu.. not datalogging working of course.. relay is going crazy  , i was thinking about wiring (stock) but once i plugged oem ecu everything sounds good... it's a EF OBD0 to OBD1.
« Reply #3 on: April 26, 2012, 06:49:02 PM »
U swap distributer wiring around? Do u have another obd1 Ecu to plug in and try?
« Reply #4 on: April 26, 2012, 07:32:51 PM »
nm.. cannot read
« Last Edit: April 26, 2012, 09:54:10 PM by jabberwock »
« Reply #5 on: April 26, 2012, 09:22:22 PM »
Do you have an Ostrich? If so, try with a chip to see if you still have the problem.
walter
« Reply #6 on: April 27, 2012, 06:28:13 AM »
Yes, right now im runing with D16z6 OBD1, i made my own distributor wiring harness, i think that's not the problem because as i said , tested with stock obd1 ecu and not cel...
walter
« Reply #7 on: April 27, 2012, 06:28:38 AM »
Yes, i do, i will burn a chip and test it again. i will let you know. thanks!.
