Author Topic: Where to buy?  (Read 10794 times)
Where to buy?
« on: May 03, 2012, 11:37:35 AM »
I need 4' 1.5" sch80 or thicker on the cheap. I can't find any were local with this. Tried looking online, but not about to spend $80 for that :P
Re: Where to buy?
« Reply #1 on: May 03, 2012, 12:04:32 PM »
Did ya check with Mandrel Bends?
Re: Where to buy?
« Reply #2 on: May 03, 2012, 12:43:05 PM »
Sch40 is all I saw.
Re: Where to buy?
« Reply #3 on: May 03, 2012, 03:12:55 PM »
ok..........i'm curious. What the hell would you need sch 80 for?
Over building a traction bar. Mine was sch80, but thats all they had at the local suppler at the time. So I went with it. Use to use it to jack the whole front end of the car up from.
Re: Where to buy?
« Reply #4 on: May 03, 2012, 03:18:21 PM »
Next on my list of what next to install/build for my car after I get back from the PNW meet.  :noel:
Re: Where to buy?
« Reply #5 on: May 03, 2012, 03:40:18 PM »
i am planning to make a write up on what you need, how much you need, links ect.
2 RH heim; http://www.speedwaymotors.com/Standard- ... ,7790.html
2 LH heim; http://www.speedwaymotors.com/Standard- ... ,7306.html
Then 2 swedged steel tubes; http://www.speedwaymotors.com/Swedged-S ... tabcontent
The tubes "Should" be 16" long. BUT i maybe wrong. I maybe test fitting everything this coming weekend. The tubes are threaded on either in for the RH heim and LH. If you need to adj you losen the locking nuts (link not included) and just spin. 5/8 is WAY over kill, BUT the price is cheap and I like over kill.
I should be making it come this weekend so I will update once it is done.
Re: Where to buy?
« Reply #6 on: May 03, 2012, 03:57:45 PM »
your links are broken
Re: Where to buy?
« Reply #7 on: May 03, 2012, 04:00:53 PM »
Looking forward to this  :noel:
Re: Where to buy?
« Reply #8 on: May 03, 2012, 06:14:03 PM »
Double check the hole size for the bolts on weirs flange for the traction bar. If I remember correctly they are 1/2" house which means u need 1/2" hiem or drill the flange out to 5/8" hole.
SQ is the SQUAD
Re: Where to buy?
« Reply #9 on: May 03, 2012, 07:30:47 PM »
http://www.summitracing.com/parts/AAF-ALL56417
Radius rods already 17" long and anodized gold.
http://www.summitracing.com/parts/CEE-3422/
Clevis bracket that works great for eg/dc LCA mounting bracket, width is a little much, i'll probably have to run bushings or shims or something to fill the gap.
http://www.summitracing.com/parts/CEE-3424/
PERFECT tabs if using 1 5/8" bar, I will take a 1.625" hole saw and shorten one of the tabs on each side so I get a 30 degree angle for the radius rod so the heim is not crooked.
http://www.summitracing.com/parts/FKB-ECM10/
Cheap heim's i'm gonna use, the car sees MAYBE 3k miles a year, and doesn't get driven in bad weather. I really don't think i'll wear these out within a year.
http://www.summitracing.com/parts/FKB-SJNL10-1/
Jam nuts...duh...
Re: Where to buy?
« Reply #10 on: May 04, 2012, 09:18:24 AM »
Redrilling to 5/8, rather have it over kill :noel:
Re: Where to buy?
« Reply #11 on: May 04, 2012, 09:23:37 AM »
2 RH heim (Price for 1/2 and 5/8 is the same $5.99); http://www.speedwaymotors.com/Standard-RH-Male-Heims,7790.html
2 LH heim (same as above); http://www.speedwaymotors.com/Standard-LH-Male-Heims,7306.html
Then 2 swedged steel tubes ($12); http://www.speedwaymotors.com/Swedged-Steel-Tube-for-5-8-Inch-Heim,2092.html
FIX!
bouncinofftherevlimiter
Re: Where to buy?
« Reply #12 on: May 04, 2012, 09:58:48 AM »
FIX!
On my Dirt Late Model we use aluminum 5/8 tubes on everything and have no issues with them. they are pretty fucking strong, the only time we have ever bent one is in a crash.
Stuff is cheap and works good, I'm surprised people aren't using these parts more.
No longer own a turbo car...
HX35 18lb 486hp/391tq
mandrel-bends
Re: Where to buy?
« Reply #13 on: May 07, 2012, 12:48:40 AM »
Your best bet would be to look into DOM, not pipe. 2.0" OD DOM, .200 wall would be roughly equivalent. It's not cheap, but it's not expensive. You could probably half your wall thickness with DOM and have the same yield strength or greater btw, DOM is mean shit.
http://www.mandrelbends.com
Re: Where to buy?
« Reply #14 on: May 07, 2012, 12:47:41 PM »
Damn good to know for next time, found some thick shit local :evil:
Re: Where to buy?
« Reply #15 on: May 07, 2012, 06:36:51 PM »
in for the full writeup(hopefully with prices). i have had a weir kit for like 3 years. im just too lazy to find all of the shit to use it
