Author Topic: B20 vtec problems plz help  (Read 10361 times)
krafthatch
  • N00B *Read Intro Sticky*
« on: May 24, 2012, 11:40:44 PM »
Here is my setup, I've got a b16 99 civic Si head that's got s2 valves with dual valve springs, turbo cams, ( don't have turbo on yet) and I have the b20z block with stock internals. I've got a chipped p72 ecu that came out of my friends b18 vtec civic and he had the chip tuned for his setup, his ecu in my car make it idle pretty rough. Makes it lumpy/choppy then when I start driving it does good. I believe his ecu is making my setup far to rich. Fucking sucks cause were I live there is no dam dyno. No way to tune my car. I know there is chrome, hondata n what not I just don't have a laptop or skills to street tune myself. Next problem is when I step on it (throttle 35% or more) the transmission, my assumption, makes loud noises like a rock pebble is flailing around in the transmission then sometimes it's like what ever it was stops till I shift into next gear? And my main big problem a Pretty dam big oil leak from the left side of the head, one leak is coming under the vtec solenoid and runs down the front of my block, the other leak is coming from the back left of the block and it's a stream of oil. Had the b20 head gask on then heard I shoul be using the b18a ls head gask. So got the b18 gasket new, put it on with arp head bolts, had the type r head studs in before. And the fucker still leaks same amount do
 Same areas. Let me know if you can help. Thanks
Re: B20 vtec problems plz help
« Reply #1 on: May 25, 2012, 12:13:54 AM »
Let me help you............. Post some porn, and answers will be given.
« Reply #2 on: July 01, 2012, 07:39:37 AM »
so much fail here... I'm guessing you WERE born yesterday
« Reply #3 on: July 03, 2012, 02:25:06 AM »
2 months later and still no porn ass hole
« Reply #4 on: July 04, 2012, 01:03:44 AM »
this guy is a peice of shit  >:(
JaredKaragen
« Reply #5 on: July 10, 2012, 02:54:35 AM »
I got answers.
Feed them porn first.
schim187
« Reply #6 on: September 02, 2012, 12:49:15 AM »
Ya this is my boy, I vouch for him...he thought I was joking to post some good shit...its coming.  Anyway, B20 vtec is gone...now trying to get him to stay away from a supercharger and throw on a turbo on this new 94 del sol siR2 w/b16a...anywayz, update to come.
 O0
