Author Topic: cant get a steady idle dirty b16 pte 880cc inj.  (Read 25921 times)
turbo4life
« on: April 19, 2009, 12:56:26 AM »
wahts up nogs anyone really good at messing with battery ofsets to make big iinjectors idle SMOOTHE!!
i been srewing with it i either get a bumpy idel or really rich idel mixture that later on gets bumpy and un consistent
heres my bin fiel
specs motor
b16a stock p30 pistons stock CR!!
cdm set up dont matter  really
pte  880cc
End the fake food.
Re: cant get a steady idle dirty b16 pte 880cc inj.
« Reply #1 on: April 19, 2009, 01:06:24 AM »
fuel pressure
« Reply #2 on: April 19, 2009, 10:35:03 AM »
Add more fuel until it leans out.
« Reply #3 on: April 19, 2009, 01:55:21 PM »
PTE 880 like to idle rich here's a bin i used b16 low cpr 9.0 when try to use the pte 1000cc injector selection for your injectors they are the same injector except 880 use smaller spray you may need to remove timing from my map my base is up 3*
« Last Edit: April 21, 2009, 04:34:25 PM by lilpooh21186 »
turbo4life
« Reply #4 on: April 19, 2009, 02:02:41 PM »
goood stuff guys! ;D  im throwing in a 2.5 bar then too even though i dont need it but ill try it out
or  i can just paste over the matching colums and call it a day?  (non boost)
End the fake food.
« Reply #5 on: April 20, 2009, 01:01:10 AM »
if you have the 2bar i would just throw it in cuz im not to shure about that copy paste stuff. how did the map work out?
« Last Edit: April 20, 2009, 10:00:12 PM by lilpooh21186 »
turbo4life
« Reply #6 on: May 05, 2009, 03:53:41 AM »
i did not throw in the 2.5 bar i played around with it with out a wide band at idel and made it richer seemed to make it idle steadey er
but then it still som times bounces up and down but at leaset now when its cold it holds a steady 1500 rpm till it warms up
End the fake food.
« Reply #7 on: May 06, 2009, 10:24:35 AM »
the 880 like to idle rich i had a steady idle at 13.3 and below any thing above would pop and misfire
« Reply #8 on: May 06, 2009, 10:11:46 PM »
Yuppers I just cranked up the fpr on the big powa big H all motor build. I had idle at the high 12's
« Reply #9 on: May 07, 2009, 11:15:45 AM »
« Reply #10 on: May 08, 2009, 04:22:30 PM »
Elaborate a little more for me please. So do you just keep adding untill it missfires so the wb  now reads lean? Or am I missing something.  :-\
« Reply #11 on: May 08, 2009, 04:39:12 PM »
i belive that was a joke
BoostForLife
« Reply #12 on: May 08, 2009, 05:08:24 PM »
Don't you add fuel until it stops popping?
« Reply #13 on: May 08, 2009, 05:59:36 PM »
What version of crome are you using?
Use fuel tools. THe bin you posted doesn't have it installed.
Is that a basemap you made or is that an actual tune? That's the weirdest looking map I've ever seen. :?: Those boost fuel values are awfully low as well.
« Last Edit: May 08, 2009, 06:01:21 PM by d112crzy »
« Reply #14 on: May 09, 2009, 11:02:47 AM »
yep keep adding fuel untill it stops popping
« Reply #15 on: May 10, 2009, 06:03:42 PM »
Wrong.
Play around with some laggy injectors sometime, low Z 750cc+ RC are some of the worst.  You'll have your shit running rich and try to lean it out only to have it stall.  The only fix is to add more fuel, and it works.
« Reply #16 on: May 10, 2009, 08:30:11 PM »
wtf how does this work does it bump up the injector timing till the point were it will fire early rather than late to compensate for the lag? couldnt you offset with injector latency from the bat-tables or the offset.
« Reply #17 on: May 11, 2009, 03:18:44 AM »
 I usually use fuel tools to get the car idling lean with missfires then go into battery offsets to richen it up.
then just use the fuel tables to tune after that. I get a smooth idle most of the time like this.
   All of this crap has to be done first, as soon as you have your laptop setup on the car for the first time I get this right and play with ect afr adjustments as the car warms up and have a solid running tune that doesn't get affected by weather changes and electrical load very much.
« Reply #18 on: May 11, 2009, 03:21:45 AM »
I just turn up the fpr up a couple pounds
« Reply #19 on: May 11, 2009, 03:37:55 AM »
Chris thats your answer to everything   ;D
ifly87
« Reply #20 on: May 12, 2009, 03:53:52 AM »
I have a hard time getting my precision 1000's to idle nice, I'm going to try one of those injector driver's thay are like $60 for a diy board.
Lol...Fags
turbo4life
« Reply #21 on: May 12, 2009, 04:19:19 AM »
how would a injector dirver help..btw wats its  supposed to do in realation to when your ecu is trying to drive the injectors  ??? ??? ??? ???
End the fake food.
« Reply #22 on: May 12, 2009, 05:38:31 PM »
Have any of you actually tried to pump up the fuel pressure yet
« Reply #23 on: May 12, 2009, 06:27:27 PM »
Quote from: turbo4life
Я действительно не пробовал все же, но я буду пробовать поднять топливное давление позже на этой неделе
« Last Edit: May 12, 2009, 06:29:21 PM by ApexSilver06MR »
ifly87
« Reply #24 on: May 13, 2009, 03:56:09 AM »
I have a stock fpr so turnin up the fuel pressure isnt really going to happen, and the injector driver will "supposedly" help peak and hold especially larger ones idle much smoother. Peak and hold injectors are supposed to get 4 amps to open the injector and then drop down to 1 amp to keep it open, when you use a resistor box you dont get that it just gets its one steady amperage, whatever depending on the resistance of the coil in the injector plus the resistance of the resistor you spliced in.
I dont have any personal experience with injector driver's but its pretty cheap and i've read good things about them. And really its how the injectors were designed to be run so might as well give them what they want.
Lol...Fags
« Reply #25 on: May 13, 2009, 08:52:01 AM »
Running the injectors how they were designed to be run has nothing to do with driver boxes.
Your problem is flow mismatch between injectors at idle.
ifly87
« Reply #26 on: May 13, 2009, 01:45:43 PM »
Peak and hold injectors were ment to be opened with a higher initial amperage then held open with a lower one, with resistor boxes you dont get that, since the internal weight of the larger injector is more they open/close slower which can be fixed with a driver.
Lol...Fags
turbo4life
« Reply #27 on: May 24, 2009, 02:39:07 PM »
nigga edit..  i can read lol
i think i just found my problem my injector wires are not  hooked up properly sequecne wise.. gonna get a wire diagram and match the colors.. injector 1 to injector on now how i have it now lol
« Last Edit: May 24, 2009, 02:41:19 PM by turbo4life »
End the fake food.
