Author Topic: Redline issue  (Read 12705 times)
Redline issue
« on: June 02, 2012, 10:14:54 PM »
Ok so I been having this issue and seem to figure out what it is. 93cx hb, vitara setup, was tuned last year on e85. Park the car for the winter time, pulled it out about a month ago, car starts and runs fine but is redlining 1500 rpm short.
Tried another chip and ecu, check and clean all the grounds, replace speed sensor. The only thing that work was replacing the speed sensor. It drove fine for a day and now its redlining short again. Tried another new honda speed sensor and nothing, which leads me to believe it has nothing to do with it. No cel are on.
Re: Redline issue
« Reply #1 on: June 03, 2012, 12:46:15 AM »
Cap and rotor? New plugs?
Re: Redline issue
« Reply #2 on: June 03, 2012, 09:37:53 AM »
Dizzy, cap, and rotor are new Honda and about one year old and less the 3000 miles.
Re: Redline issue
« Reply #3 on: July 01, 2012, 07:33:12 AM »
Maybe the ECT sensor isn't reading right or is broken. Most ems's will give you a lower redline for colder coolant temps unless you change it.
JaredKaragen
Re: Redline issue
« Reply #4 on: July 10, 2012, 02:55:30 AM »
Need to see what ecu reports.... Datalog son.
crxin
Re: Redline issue
« Reply #5 on: September 10, 2012, 08:56:54 AM »
in your ecu do you have one of those two timer zif sockets where you can run two chips in one ecu?
