Pages: 1 [2] 3   Go Down
Author Topic: I need a custom manifold in CONNECTICUT! civic EF!!!  (Read 48381 times)
Re: I need a custom manifold in CONNECTICUT! civic EF!!!
« Reply #30 on: June 12, 2012, 10:25:35 PM »
google?
« Reply #31 on: June 12, 2012, 11:37:55 PM »
er304            you can use pretty much anything, though.  316 is too wet and flows too quick if you're slow as fuck like me.
« Reply #32 on: June 12, 2012, 11:44:16 PM »
308L
The_Beave
  • The Red Tape Avenger
    • Beaver Built Blog
« Reply #33 on: June 13, 2012, 12:08:27 AM »
309 to weld mild to 308 or 304 stainless.
You can also use 316, but that is REALLY expensive.
Not so obvious and ruthlessly odd.
Fab blog: http://beaverbuilt.blogspot.com
4door89
« Reply #34 on: June 13, 2012, 12:37:44 AM »
A lot of dudes are sucking 309L's dick on this site...
http://cr4.globalspec.com/thread/6367
309 it is...
I have stainless wire in my lincoln right now...
« Reply #36 on: June 13, 2012, 09:42:18 AM »
Too bad the foundry I work at pours 316 and 316l once/2wks right now, I want to try and make a pattern and corebox to make manifolds.
4door89
« Reply #37 on: June 13, 2012, 01:39:56 PM »
What type of shapes and sizes do you guys make? Everything?
« Reply #38 on: June 13, 2012, 01:42:57 PM »
We pour casting, usually 4" to 16" turbine pump impellers, and some bodies and volutes.
We are a brass/bronze foundry but we are getting major customer demand for 316L/316 castings.  :noel:
DasPoop
« Reply #39 on: June 13, 2012, 09:50:38 PM »
russ you know you have to make a killer ballin brass or bronze compressor housing  :P
« Reply #40 on: June 13, 2012, 09:59:33 PM »
Yeah but it will weight twice the aluminum comprossor, unless I do a CDA958 then it will be a little closer aluminum.  :noel:
4door89
« Reply #41 on: June 13, 2012, 10:27:51 PM »
I'd buy that for a dollar!
« Reply #42 on: June 13, 2012, 11:44:30 PM »
309 it is...
That site is filled with durkas who appear to be engineers.
Never trust a durka, never listen to an engineer.
4door89
« Reply #43 on: June 13, 2012, 11:56:30 PM »
4door89
« Reply #44 on: June 17, 2012, 01:40:04 PM »
Looks like Corey is going to be doing my manifold. Hes got a couple more projects to bang out then I'm up. Cant wait for that shit be done.
Now my only question is, how high compression am I going to do on stock sleeves/bore with pistons and rods.
My goal is 350hp.
Stock B16 Head, ITR cams, 70mm TB, port matched skunk2 IM, 650cc Precision injectors
T3_T4E-Standard Bearing- H61 compressor wheel- Dry- Dynamic- Stage 5 turbine wheel- Standard .63 a/r turbine housing
I'm going to try to build boost as soon as possible. And I would like a power band with emphasis on low-mid range.
I know what "GOOGLE" says, I am simply thinking out loud...
« Reply #45 on: June 18, 2012, 07:45:05 AM »
Meant 308.  Been a while sense I was welding in the garage.  308 is all I run.
4door89
« Reply #46 on: June 18, 2012, 06:52:19 PM »
Wait i thought 309 was preferred for mild to stainless.
4door89
« Reply #47 on: June 18, 2012, 09:00:35 PM »
T3 blanket from siliconeintakes.com $50
« Reply #48 on: June 21, 2012, 12:50:17 AM »
My goal is 350hp.
 low-mid range with a 61mm stg 5 .63 turbine. on a b series. hahahahahahaha Really dude? You ever been in a turbo b series car?
Seriously you need to take a big look at your plan and change everything about it. You just wrote out a recipe for a power band from 6000-9000 rpm. efficient cam, efficient intake/tb, efficient turbine. who in the hell gave these as suggestions?
4door89
« Reply #49 on: June 21, 2012, 09:34:43 AM »
is the turbine too big? Even with 10:1 or 10.5:1???
« Reply #50 on: June 21, 2012, 01:23:41 PM »
If your only going for 350 and semi quick spool I would have tried to go with a simple 50 or 57 trim.
4door89
« Reply #51 on: June 21, 2012, 01:42:22 PM »
That's what I've had forever. Trying to use what i already own. I also want some room for more down the road.
Oh well.
I might be getting a STR intake manifold for $250 for my built GSR head.
« Reply #52 on: June 22, 2012, 04:39:02 PM »
The powers going to hit you in the face. It should be fun.
4door89
« Reply #53 on: June 27, 2012, 02:37:42 AM »
Some pics of the old setup...
So one night, i think i was high... I decided to extend my dump out passed my oil pan.
Only problem is, it only lasted about 2 weeks. I guess with all the weight, that bitch broke from the weld on the wastegate flange.
Scarlett Johansson is a whore!!!
« Reply #54 on: July 01, 2012, 12:00:40 AM »
BLOX log manifold, two t3 flanges, two 45* elbows (aluminized steel tube). Run the outlet of the manifold down & over to the turbo and enjoy.
d-rail
« Reply #55 on: July 06, 2012, 10:54:44 AM »
I didn't feel like reading your whole post but get ahold of eville. He does baller shit at a crazy price. He's like a cheaper whore without the payback and with customer service.
« Reply #56 on: July 06, 2012, 02:49:49 PM »
TRUTH!! Rocked out a splog for me for dirty cheap!
4door89
« Reply #57 on: July 09, 2013, 12:33:42 AM »
I went a completely different route.
« Reply #58 on: July 09, 2013, 12:44:39 AM »
Kinda reminds me of spikers old mani
« Reply #59 on: July 10, 2013, 12:56:19 AM »
Even the car color...except with less homo. ;DDD
Pages: 1 [2] 3   Go Up
