Author Topic: How-to properly fix a totaled GM...  (Read 20816 times)
JaredKaragen
« on: June 06, 2012, 04:37:58 AM »
Re: How-to properly fix a totaled GM...
« Reply #1 on: June 06, 2012, 08:35:26 AM »
Wow......
« Reply #2 on: June 06, 2012, 10:06:57 AM »
I'm surprised the sway isn't broken. They usually shear on their own without a crash.
I'm also surprised someone has enough sack to drive that fucker.
« Reply #3 on: June 06, 2012, 06:58:06 PM »
Wow, even the carrier is welded up. Can't say I have ever run across something that sketchy.
« Reply #4 on: June 06, 2012, 10:08:31 PM »
Dont lie we can tell those are your welds  :noel:
« Reply #5 on: June 06, 2012, 10:10:19 PM »
Looks fine to me.
« Reply #6 on: June 06, 2012, 10:15:57 PM »
« Reply #7 on: June 08, 2012, 11:13:49 AM »
Shit like thats common where I work. Rednecks make me laugh
bouncinofftherevlimiter
« Reply #8 on: June 08, 2012, 11:29:30 AM »
The tie-rod repair is the best, i wonder if the re-adjusted toe after the blatant inch of overlapping?
No longer own a turbo car...
HX35 18lb 486hp/391tq
MAJORAHOLE
  • fuckin C-unt
« Reply #9 on: June 08, 2012, 11:37:29 AM »
i bet it tracks straight as an arrow... :-X
DasPoop
« Reply #10 on: June 09, 2012, 03:21:13 PM »
idk about you but how many threads are your tier ods threaded in? i would say mine are at least .75-1" in
JaredKaragen
« Reply #11 on: June 09, 2012, 07:07:59 PM »
We bought off a customer who sandwitched it in between two cars, set back both front tires pretty bad, broke the knuckle, bent all strafing bars/tie rods.
To be able to move it around the shop/street @ work we quickly tried welding the arm, it broke off two times on my boss, so I went in, welded the piss out of it (oil soaked), and added a support triangle.  We had to plasma and shorten the tie rod due to hub setback.
I thought you guys would get a kick out of it.
Ironically It's holding, and is able to be driven in and out of parking spaces and the street.
Strictly temp and for humor :)
NoPistons!
« Reply #12 on: June 11, 2012, 05:16:20 AM »
That knuckle scares the shit out of me.  Tie rod looks ok though.  Bump steer adjusted....kinda probably not.....
« Reply #13 on: June 11, 2012, 01:14:59 PM »
bump steer wouldn't change unless the mounting point of the tie rod changed, either on the inner or outer joint. What happens in the middle of the tie rod does not affect bump.
JaredKaragen
« Reply #14 on: June 11, 2012, 02:19:08 PM »
Both front tires are "set back" at least 2-4" if not more!!!  So the tie rods ended up being too long when the knuckle was re attached, and the passenger tire rubber the rear of the fender like mad!
« Reply #15 on: June 29, 2012, 11:59:30 AM »
That explains why you welded it to the castle nut. Not really but kinda. ;)
NoPistons!
« Reply #16 on: September 17, 2012, 12:55:28 PM »
You are correct and my bad.  I'm not sure what the fuck i was thinking.  The pivot on the rack and ball joint stuffed into the spindle did not change.
I'm surprised as fuck that thing supports it's own weight PARKED let alone moving.
JaredKaragen
« Reply #17 on: September 17, 2012, 02:18:07 PM »
ya...
shop picked it up for $500 while simultaneously taking in $3,500 on another...   lol
and when he saw us move dive it a day later he was amazed...
we just needed that bitch to be able to be driven around and moved out of the way instead of disabled.
shit is funny as fuck....
looks soooooo much better in person!
