Author Topic: IACV questions, hunting idle  (Read 34883 times)
hatchboy
  • Bombs Over Baghdad
« on: June 16, 2012, 08:30:59 PM »
type r head, gsr block.
Have had a hunting idle issue that i need to resolve, Starting goofing off with it today finally, when engine is cold it idle's fine, when it is warmed up it hunts from 900-1400 ish. I unplugged the IACV and the engine stalled which tells me the IACV is in fact working, I have taken it out and cleaned it previously.
Started looking underneath and at schematics in the service manual, turns out the passenger side bung on the IACV connects below the throttle body, that is connected fine.
Looked at the other side of the IACV on the drivers side bung, the hose is coming off and plugged with a bolt. I realize that it is supposed to be connected to the crossover pipe on the block but my crossover pipe on the block does not have a bung to connect the hose.
Could this be the causing factor of my surging idle? Considering coolant is coming in to the IACV but not being let out? Or is the line from the crossover pipe actually the feed line?
DSMR
Re: IACV questions, hunting idle
« Reply #1 on: June 16, 2012, 09:26:49 PM »
Do you have a FITV on your Throttle body? If so, take off the pipe on the throttle body. While it is idling, block off the bottom port with your thumb (IIRC it is the bottom port). If the idle goes down like it should, your issue is your FITV needs to be cleaned/adjusted.
hatchboy
« Reply #2 on: June 17, 2012, 12:55:22 AM »
No FITV on it as it is a 98 type r head/manifold. Only hole is at the 9'oclock position going to iacv i assume.
JaredKaragen
« Reply #3 on: June 17, 2012, 02:01:31 AM »
Stock manifold... Good.
Stock unmolested throttlebody?
hatchboy
« Reply #4 on: June 17, 2012, 12:07:46 PM »
Yes, completely stock. I am pretty sure the IACV is working correctly, with it unplugged i can set base idle around 550 with very very minimal fluctuation. With it plugged in it hunts constantly 800-1400.
I am starting to lean towards a vacuum leak somewhere, not to try and diagnose it.
I had it running last night, sprayed carb/choke cleaner over pretty much every vacuum line etc and did not observe and type of rpm change.
Then i hooked up my hand pump vacuum tool, and realized i was a retard because i was not going to be able to pull any vacuum with it at all.
Next step to finding a vacuum leak?
« Reply #5 on: June 17, 2012, 12:15:11 PM »
The coolant hoses are there to keep the valve from freezing up during cold conditions.
If you plugged the IACV hole iwth your finer and the engine stalled, I highly doubt you have a vacuum leak.  The fact that you sprayed flammable cleaner around the manifold and saw no appreciable change in RPM also leads me to believe there is no vacuum leak as well.
Are you running a non-stock calibration?  If so, what EMS platform?
I would check your minimum air rate.  Bring the RPM up by opening the throttle plate, plug the IACV opening with your finger, and slowing close the throttle plate so that the engine will continue to idle.  I should be about 450-550 RPM if I recall correctly.
I think there is a spec for it in the FSM.
JaredKaragen
« Reply #6 on: June 17, 2012, 03:43:32 PM »
If the ecu is stock;  it must be vacuum leak, sticking iacv, or low vacuum reading seen by PCM; possibly incorrect TPS reading in ecu also.
Check your sensor output through a DLC of some sort;  if using an ems it needs to be tuned properly...
It's soooo much easier to do this kind of diagnosis in person...
« Reply #7 on: June 17, 2012, 04:27:52 PM »
This.
hatchboy
« Reply #8 on: June 17, 2012, 11:09:28 PM »
This.
P28 w/crome pro tuned by Dave Lee
It has done this since day one of this new engine, with the limited time myself and dave had while street tuning two years ago, we couldn't figure out why it was fluctuating.
« Reply #9 on: June 18, 2012, 12:45:38 AM »
FITV not fully closed?
Brake booster vac leak?
hatchboy
« Reply #10 on: June 18, 2012, 02:21:53 AM »
No FITV on this manifold/Throttle Body.
Brake Booster is a valid possibility, I didn't spray around it too much. If that was leaking would it affect my braking at all?
I am going to give it a once over again and see if its got a vacuum leak, if not, it has to be the tune..
JaredKaragen
« Reply #11 on: June 19, 2012, 03:35:28 PM »
This.
This explains it.
100% tune related is my guess if it's not a sticking iacv.
I have had some cars be a royal PITA with idle; especially ones that like to dip down very low after a pull.
Most of the time I can smooth it out and get it right.  The rest of the time I was able to get it out on a retune later down the road.
I've been able to get stage3+ cams to idle smooth and return to a smooth idle at roughly 900rpm on 1k+ injectors...   It takes a LOT of fancy timing/fuel table modification, but it can be done...  It's just tricky; like the idle on some vehicles.
hatchboy
« Reply #12 on: June 19, 2012, 04:30:08 PM »
This.
This explains it.
That is what i am leavning towards as well, I am going to pull off the IACV one more time and soak it in cleaner, if that doesn't clear it up, im going to have to see if i can get ahold of leed to come do his work again.
I can't find any vacuum leaks whatsoever, the only other thing it POSSIBLY? could be, is that i have the GM 3 bar coming off the vac manifold, should it has its on source directly from the IM?
« Reply #13 on: June 19, 2012, 05:40:27 PM »
This.
This explains it.
YES  :noel:
JaredKaragen
« Reply #14 on: June 19, 2012, 07:33:16 PM »
It's always ideal to have the map on its own dedicated vacuum source with the largest connection hose possible....
Moving it I highly suggest a retune as well.
hatchboy
« Reply #15 on: June 20, 2012, 02:04:24 AM »
possible bubble in coolant line at temp switch. It's happened to me a few times on a b16.
it's worth checking it out.
I have drained coolant three times since i built this latest engine, i would think that a bubble in the same spot is unlikely yes?
JaredKaragen
« Reply #16 on: June 20, 2012, 03:52:32 AM »
I doubt it.
If you ever doubt bleeding cooling systems look into the "airlift". Worth it's weight in gold.
It puts the cooling system in a vacuum, then using that vacuum you can assess potential leaks; and finally use it to draw coolant into the system.  It will fill all crevices and leave little if no air bubbles in the system.  No bleeding, no burping, no stress or chances of issues.  Fill and drive away without sweating anything.
hatchboy
« Reply #17 on: June 20, 2012, 11:00:17 AM »
I doubt it.
Well when I filled it this last time, i had the front of the car on jack stands and burped it with squeezing the hoses etc. Today when i get home from work i am going to re-route the vacuum hose from the map straight to the manifold instead of on the very end of the vac manifold and see if it makes a difference.
hatchboy
« Reply #18 on: June 20, 2012, 07:32:17 PM »
not unlikely at all, the bleed off screw is the high point of the system so air bubbles go there.
Having the front of the car up on jack stands will throw off the high point. You are supposed to bleed the coolant system on level ground.
michael,
Last time i checked, My car didn't have a bleed screw.......
98 jdm itr head.
I think they stopped the bleed screw stuff in the higher years for some reason.
hatchboy
« Reply #19 on: June 21, 2012, 12:52:05 PM »
Hey don't act like I should know if it has one or not. I don't buy any hype r stuff.
however I still say double check it again can't hurt.
What wire harness are you using?
Custom harness that i built. And no, it does not have a bleed screw. I think its all 96+ motors or something that don't have bleed screws, not positive on the year, but almost positive that the higher years dont have one.
hatchboy
« Reply #20 on: June 21, 2012, 12:58:07 PM »
hatchboy
« Reply #21 on: June 21, 2012, 09:27:44 PM »
could the ecu be looking for a FITV?
Have you replaced the IACV yet?
no and no i havn't replaced it, just taken it off and cleaned it a couple times.
« Reply #22 on: June 25, 2012, 07:18:40 PM »
Edit:
My IACV does have coolant lines, nevermind.
« Last Edit: June 25, 2012, 07:24:09 PM by Tim »
JaredKaragen
« Reply #23 on: June 25, 2012, 08:59:56 PM »
Ya the cooling lines are just for very cold temps...  Not much of a worry.
hatchboy
« Reply #24 on: June 25, 2012, 09:21:52 PM »
I am almost 100% positive its the tune. With myself and dave not having a lot of time on it, and precision 1000cc's i suspect it just needs to be massaged out a little more.\
I took the IACV off again, cleaned it again, checked it with 12v source and the plunger is operating normally. I moved the MAP to its own vacuum source with a big hose, no change in idle.
Warmed it up, unplugged IACV and set base idle, although it was still fluctuating at 500rpm slightly, so it haz to be the tune.
Everyone agree?
« Reply #25 on: June 25, 2012, 09:24:19 PM »
Everyone agree?
Agreed  :noel:
hatchboy
« Reply #26 on: June 25, 2012, 10:42:06 PM »
Everyone agree?
Agreed  :noel:
Also. TPS in closed position reads .51  Close enough yes?
« Reply #27 on: June 25, 2012, 10:48:50 PM »
Everyone agree?
Agreed  :noel:
I use my datalog screen to adjust my TPS to be near zero -1% to 2%.
If ya reading like 10% on datalog , or the TPS has a dead spot when moving the throttle real slow, could cause some problems with idle.  :noel:
hatchboy
« Reply #28 on: June 26, 2012, 02:36:30 PM »
Everyone agree?
Agreed  :noel:
No dead spots, everything said .49 to .50 is dead on, I am .51 and thats how it was when i was NA and it ran like a raped ape.
« Reply #29 on: July 01, 2012, 08:00:40 AM »
i have the GM 3 bar
I found your problem, that and precision 1000's are that precise at idle. Watch the datalog for AFR's and vacuum, I'm going to guess both start swinging unusually when you unplug the IACV port. By swinging I mean they read wrong since the MAP isn't giving the correct value, and the tune at idle isn't that great.
