Author Topic: Highroller is going to do the unimaginal, try to tune a car! HELP  (Read 20355 times)
OK, I'm really dumb when it comes to PC computers and tuning, I understand how a cars computer works and how to fix the fuck out of it but I know nothing about tuning.
I want to tune/fuck with my civic, its chipped on crome right now with a street tune and I have a lap top, The car has a aem wideband with data log wires.
What do I need to buy, what do I need to down load? Can you data log with normal crome? Whats the difference with crome gold?
Re: Highroller is going to do the unimaginal, try to tune a car! HELP
« Reply #1 on: June 29, 2012, 10:22:50 AM »
You can datalog with crome Pro, crome free no datalog.
For datalog while using Crome free use freelog.  :noel:
Crome Pro I got for $50 from a guy on D-series and it can be used on up to three laptops/desktops.
« Reply #2 on: June 29, 2012, 12:35:29 PM »
First time I tuned, I eyeballed the wideband & tach, adjusted in Uberdata, then reburned the chip. If you can get the tune close to start with, you don't need datalogging unless you want to get it perfect. The biggest problem will be figuring out what you need to do to crome just to get to the point you can tune it. I can't even remember, there's so much bullshit with removing checksums, adding boost tools, tilting your head at a 47* angle, etc. That and I couldn't get a new license for a few years til he put an automated app on his website.
In other word, don't BUY crome pro, use crome free to get an idea then get ectune/neptune/s300 later. Just make sure you know what the AFR's should be, and know what detonation sounds like.
« Reply #3 on: June 29, 2012, 03:30:29 PM »
Vice grips on return line, Rock the dizzy back, and hold foot to the floor!!
« Reply #4 on: June 29, 2012, 08:37:25 PM »
This
« Reply #5 on: June 30, 2012, 10:37:24 AM »
lol, love this place!
« Reply #6 on: June 30, 2012, 03:54:09 PM »
Get an ostrich and a chip burner. And a spare motor.
« Reply #7 on: June 30, 2012, 05:47:11 PM »
Add some det cans, and rock out.
« Reply #8 on: June 30, 2012, 08:51:13 PM »
« Reply #9 on: July 01, 2012, 01:27:04 AM »
whats a good chip burner? is there only one ostrich?
« Reply #10 on: July 01, 2012, 07:30:51 AM »
Moates Burn2 if you want it easy, willem chip burner if you want it cheap. There's only one moates ostrich.
« Reply #11 on: July 01, 2012, 02:16:10 PM »
For the added convenience I would go with the Moates chip burner. You could also go with a demon from Moates instead of a ostrich and a Honda log.
« Reply #12 on: July 01, 2012, 06:18:12 PM »
please explain more  :)
« Reply #13 on: July 01, 2012, 07:13:29 PM »
A demon is a ostrich and a data logging cable all in one. And it mounts in your Ecu permanently. Then you only have 1 cable to connect to your laptop instead of 2. And its pretty close to the same amount as a ostrich and a Honda log combined. It does the job of both all built into 1 thing.
« Reply #14 on: July 01, 2012, 08:55:41 PM »
Ah, that would be cool but not for tuning more then one ecu/car then I suppose.
Can I pull the current tune out of my car now to play with it or do I have to start from scratch?
« Reply #15 on: July 02, 2012, 12:53:43 AM »
If you get a chip burner then yes. You can pull the tune off it and fuck with it. Yes it will have to stay in that Ecu. But if you get a burner you can burn your final tune on a chip if need be.
« Reply #16 on: July 02, 2012, 01:09:08 AM »
gotcha, I'll order that shit up and play with it, then more questions! lol
Thanks!  O0
« Reply #17 on: July 02, 2012, 11:07:41 AM »
Thanks!  O0
Nig I have a burnner just collecting dust, I will loan you. Let me know.
« Reply #18 on: July 02, 2012, 12:54:39 PM »
The thing to know is the "gold" rom that works with the emulators can't be put on a chip later. However, the normal type that you can change MAP sensors, injector size, etc can be tuned on the emulator then burned to a chip.
I could even take your BIN file via email, burn to a chip, then mail it to you. Hell, if you sent 2 tunes I could make a 2-timer that would let you switch between them. This would be handy if you made a start/idle only bin for storage, wideband and narrowband tune, cutout tune, etc.
« Reply #19 on: July 02, 2012, 11:34:08 PM »
Buy Ostrich 2 from http://www.moates.net/.
Buy some kind of AFR meter.
Buy boost gauge.
Use Crome free.
Basically you need to know the 2 axis of tuning (pressure and rpm) and with the AFR you set the 3rd axis that is fuel...
Create a basemap or use one from http://www.xenocron.com/bins/index.php?PHPSESSID=f6adbe8f08bffd9e95bf049858102ecf&direction=0&order=&directory=Crome
that is close to your engine setup.
You can also follow this guide: http://www.xenocron.com/install/CromeGuide.htm for some useful tips.
Just download the last version of Crome, not Crome 1.5 like the tutorial.
Usually if I see that there's not enough fuel at first start up I assume it's the same for the entire map and I select all the cells and add fuel to the whole map by % increase. When it's near a stable state without being perfect then I do it more precise tune near the idle.
Then you start to drive around and keep an eye on AFR to make sure you're not out of target and adjust it when it's the case.
I use the higher gears and brakes (accelerate while pushing on brakes) to tune load because when you're not on a dyno rpm is increasing to fast to see the pressure and AFR unless you use datalog (even then...). You don't do it too often obviously...
Always select a zone, not a single cell because there's an average made on surrounding cells.
Just follow the Xenocron guide anyway...
DreaMeR
« Reply #20 on: July 03, 2012, 08:27:24 PM »
In crome adjust your injector size then go to advanced setting. Injector voltage offset. Use a bnumber between 1 and 50, getting your idle close. Don't adjust the fuel map til after adjusting injector offset.
« Reply #21 on: July 03, 2012, 10:38:09 PM »
You sir are going to fuck up anything that is possible to fuck up  O0
« Reply #22 on: July 04, 2012, 08:52:41 AM »
BAN
