Author Topic: what tool for make this wg holes?  (Read 19785 times)
walter
« on: July 01, 2012, 01:59:55 PM »
and what ppl use for cut the pipe with that "form"?
Re: what tool for make this wg holes?
« Reply #1 on: July 01, 2012, 02:55:57 PM »
Holesaw, die grinder, tube notcher.
« Reply #2 on: July 01, 2012, 11:25:52 PM »
probably a hole saw and layed on a pipe with a larger diameter and hammered
« Reply #3 on: July 02, 2012, 12:34:49 AM »
Get pipe that you plan to use for wastegate. Wrap a sheet of paper around it, tape it together to make a paper pipe.
Now take paper pipe off of metal pipe.
Push paper pipe against header where you want it to go. Cut  the paper a little where it hits. Keep doing this till it fits perfect.
Once paper fits good, push it against header and draw a line around collector where it fits against. This line is what you need to cut.
Now drill a 1/4" hole inside the line you drew. Then up a size till it 1/2", then get a 1/4" carbide bur with an air grinder (20 bucks at harbor freight) to make the hole bigger till ti touches the line you drew using the paper pipe.
« Reply #4 on: July 02, 2012, 12:46:41 PM »
Works better with spagetti noodles and rubber bands. A tubing notcher is basicly a hole saw on a very ridgid axle that can be pushed in/out, driven by any drill you can fit. Very little deflection with a decent notcher. With coolant, the hole saw will stay sharp for a while.
bouncinofftherevlimiter
« Reply #5 on: July 02, 2012, 06:45:53 PM »
the pipe i used for my waste gate was a 90* that i cut to fit, gave me a sweet swooping angled transition from the runners to the WG....
No longer own a turbo car...
HX35 18lb 486hp/391tq
civiceggturbo
« Reply #6 on: July 12, 2012, 08:45:08 PM »
plasma cutter rough, burr to clean up
weirtech
    • Weir Technologies Inc.
« Reply #7 on: July 14, 2012, 12:24:00 PM »
that wastegate branch looks like it is made from an elbow.  i'd cut it with a plasma... but only after making the branch first, then drawing the outline onto the collector.
aaron
« Reply #8 on: July 15, 2012, 12:50:35 AM »
it is.
« Reply #9 on: July 31, 2012, 10:27:02 PM »
hammer, screwdriver, vodka
