Author Topic: sohc turbo help  (Read 17453 times)
90sexyrexy
sohc turbo help
« on: August 08, 2012, 07:10:05 AM »
if i plan on going turbo in my 90 crx and i have a sohc zc should i put a d16z6 head on this block or just swap a whole d16z6 motor in? my goal is to beat a subaru wrx sti so im looking to do around 400 hp. is this an acceptable goal? or is this even possible with a single cam? id like to do a single cam but i also want it to be a reliable car. can someone help me out that knows about turbos? i know barely anything when it comes to turbos. thank you so much!
Re: sohc turbo help
« Reply #1 on: August 08, 2012, 08:14:41 AM »
You really need to know exactly what ya have first.
ZC SOHC vtec or no-vtec.
IF vtec, look at the intake side of the casting and it should be a P08 casting, if it is you already have a D16z6 head.
If not, look up mini-me vtec on google or just go to D-series.org and search.
Also this your first post and thread on here, go Force Induction section, lookup Free Turbo Kits ( http://www.realhomemadeturbo.com/forum/index.php/topic,25.0.html ) or NOOB of the year! ( http://www.realhomemadeturbo.com/forum/index.php/topic,14535.0.html )
Follow example of how your first thread should be done.
If ya want you can delete this thread and start over to make you look better.  :noel:
Re: sohc turbo help
« Reply #2 on: August 08, 2012, 10:43:17 AM »
It doesnt take much to beat a sti.
90sexyrexy
Re: sohc turbo help
« Reply #3 on: August 09, 2012, 01:54:55 AM »
how do i do a first post? i dont get it? i have to post porn?
Re: sohc turbo help
« Reply #4 on: August 09, 2012, 01:29:38 PM »
Yes, its like getting jumped into a gang. U posting porn is your initiation. You either down with us, or your a homo, and you should just delete your account.
90sexyrexy
Re: sohc turbo help
« Reply #5 on: August 11, 2012, 05:27:04 AM »
ok ill do it :) look for my nest post!
JaredKaragen
Re: sohc turbo help
« Reply #6 on: August 14, 2012, 12:58:53 AM »
So true.
400hp is a serious goal for a d. I have a friend who is having issues with 300.  Dyno day soon, we will see what it is now.
Your looking at all forged internals, a cam, a large ball bearing turbo; possibly a sleeved block, and a lot of sequential tuning.   Shop tuning for a reliable setup will cost big time; trust me.  Don't expect it in one 3 hour session.
Hopefully your pocket book can cough up 2-3k for everything that will be needed.
If you shoot for 250ish; now your really in the right range for a novice turbo enthusiast.  Don't shoot the moon; work your way up.  You'll thank me and your pocketbook in the end.
Re: sohc turbo help
« Reply #7 on: August 14, 2012, 03:44:41 PM »
I don't think noobs have any idea what 400whp feels like. For example, a lot of people think a lsv is fast. Those same people may some day put down 250whp with a ebay turbo kit, they will think it feels like 400. Until they actually have 400 and realize its a fucking handful. I Cant imagine what 600+ would be like.
bouncinofftherevlimiter
Re: sohc turbo help
« Reply #8 on: August 14, 2012, 08:52:44 PM »
My friend has a z6 that made 408? wheel, and he has a simple build.
wiseco pistons
eagle rods
ARP head studs
780cc injectors
ebay cast mani
HE351cw holset
Tuned by Sewell with ECTune, at like 20lb i believe, on pump 93, its not really that difficult....
No longer own a turbo car...
HX35 18lb 486hp/391tq
Re: sohc turbo help
« Reply #9 on: August 14, 2012, 11:10:28 PM »
Jarred, what the hell are you talking about?
300whp on a D is easy. Vitara pistons, eagle rods, a little head clean up, cast manifold and an eBay t3/to4e at 15-17psi will do it easy. I DD'd that exact setup and made 310/240 on 15psi. That was stock z6 intake, TB, and cam. I added valve springs, 28psi and 130 shot and made 487whp without changing anything else. Stock A6 sleeves too. It is well documented that 600-ish is their limit.
Re: sohc turbo help
« Reply #10 on: August 14, 2012, 11:31:09 PM »
Still waiting  :noel:
JaredKaragen
Re: sohc turbo help
« Reply #11 on: August 15, 2012, 12:35:27 AM »
1.5; not as easy.
I mainly say because 99% of heads don't go for proper tuning or assembly techniques.
Re: sohc turbo help
« Reply #12 on: August 15, 2012, 08:10:25 AM »
A z6 or a6 head on there and it's all the same.
Re: sohc turbo help
« Reply #13 on: August 15, 2012, 10:02:29 AM »
Made 500 on 30psi JD tuned, had a 120shot direct wet shot, but ectune update owns!
Re: sohc turbo help
« Reply #14 on: August 15, 2012, 10:21:47 AM »
Mine had a lot more in it, we had to pull it back for traction on the dyno. 487 was the best we could get to hook once the nitrous button was hit.
