Author Topic: B16 diff in GSR transmission  (Read 14180 times)
hamburgler
« on: April 22, 2009, 11:15:03 PM »
Ive got a Quaife LSD in my b16.  The gears and syncros are shot, so I plan to put this LSD in my other GSR tranny.
Will the b16 LSD literally swap over, or do I need to get a different style of bearing to put the b16 LSD in a GSR tranny?
Also, if someone has a blown up diagram of a GSR tranny with part numbers that would be great.
Since its off right now, I plan to do the diff bearings, and the main and counter shaft bearings.
Re: B16 diff in GSR transmission
« Reply #1 on: April 23, 2009, 12:47:49 AM »
the ring gears on B16 and GSR trannys are diff.. if you keep the ring gear on it you should be legit...
hamburgler
« Reply #2 on: April 23, 2009, 01:25:45 AM »
What about the GSR tranny having a tapered roller bearing at the diff and the B16 doesn't...or at least it looks as thought it doesn't.
« Reply #3 on: April 23, 2009, 04:32:56 AM »
knock the GSR tapered outer races out, installed the B16 Quafie, shim as needed.
