Author Topic: DIY ecu tester?  (Read 20822 times)
walter
DIY ecu tester?
« on: August 31, 2012, 08:31:29 AM »
any how-to?
saw this and looks homemade , not sure if somebody have any info for make one of these..
I know moates sell these  :noel:
Re: DIY ecu tester?
« Reply #1 on: August 31, 2012, 10:10:41 AM »
Go to PGMFI.org foresale thread, there was a guy on there selling the one Zeno has for $80 + shipping.  :noel:
walter
Re: DIY ecu tester?
« Reply #2 on: August 31, 2012, 10:23:15 AM »
didnt found it.  :-\
Re: DIY ecu tester?
« Reply #3 on: August 31, 2012, 11:11:59 AM »
http://forum.pgmfi.org/viewtopic.php?f=3&t=23165 for $150  :noel:
search for a guy w/ screen name VIPperformance he had one up for $85 plus shipping,  :noel:
walter
Re: DIY ecu tester?
« Reply #4 on: August 31, 2012, 11:20:27 AM »
he had a demon for 80$ , of course it's sold .
I meant is someone made a homemade one.. thanks anyway.
Re: DIY ecu tester?
« Reply #5 on: August 31, 2012, 11:26:01 AM »
I bought that demon and he PM me that he had an engine sim. for sale for $85.  :noel:
But yeah I'd like to see a RHMT version, I doubt anybody on here is doing one.  :noel:
Re: DIY ecu tester?
« Reply #6 on: August 31, 2012, 12:36:40 PM »
not sure the purpose of all that jazz. Fucker works plug in it a car,doesnt work you suck at soldering
done
Re: DIY ecu tester?
« Reply #7 on: August 31, 2012, 01:34:40 PM »
i made 2 of them years ago. obd0 and obd1. it was just a 9v battery to power up the ecu, and a LED on the CEL wires. it blink? ECU is fine, solid? try again.
made it when i blew up the crx then sold it. so i couldnt in car test anymore.
walter
Re: DIY ecu tester?
« Reply #8 on: August 31, 2012, 02:22:15 PM »
how did you do that exactly?
Re: DIY ecu tester?
« Reply #9 on: August 31, 2012, 03:33:42 PM »
I remember that stole your idea to test a couple obdo ecu's
worked perfect
Re: DIY ecu tester?
« Reply #10 on: August 31, 2012, 03:58:06 PM »
power, ground, LED signal from MIL ECU wire, other side to ground.... ill look for pics later, they are probably on old comcast.
Re: DIY ecu tester?
« Reply #11 on: August 31, 2012, 04:06:22 PM »
obd0 i used pins: A13 power, A16 ground... you hook up a standard 9v battery. if the light in the ECU blinks your golden.
obd1 i used pins: A25 power, B2 ground... one side of LED to power the other to A13, D4 to ground... again 9v battery for power/ground.
havent found pics yet. im sure they are on my PC... and i still might have these testers around somewhere.
Re: DIY ecu tester?
« Reply #12 on: August 31, 2012, 04:18:29 PM »
found this one that leed did forever ago. way nicer than one i made lol
only tests that its not a solid CEL, not to trouble shoot the functions of the ECU.
« Last Edit: August 31, 2012, 04:26:53 PM by turbohf »
Re: DIY ecu tester?
« Reply #13 on: August 31, 2012, 04:49:49 PM »
Awesome  :noel:
walter
Re: DIY ecu tester?
« Reply #14 on: August 31, 2012, 04:54:37 PM »
i'd say fucking awesome!!! ;DDD
thanks for info!.
Re: DIY ecu tester?
« Reply #15 on: August 31, 2012, 04:58:23 PM »
no problem, here to help :Jew:
walter
Re: DIY ecu tester?
« Reply #16 on: August 31, 2012, 05:06:14 PM »
another question, how to pin for read codes? thanks HF!!!  :D
Re: DIY ecu tester?
« Reply #17 on: August 31, 2012, 05:40:23 PM »
that is to read codes. it will auto throw iat/iacv/and some other cool shit lol.
walter
Re: DIY ecu tester?
« Reply #18 on: August 31, 2012, 05:47:52 PM »
wow! nice!!! double job, check if ecu is good and if there is a cel, it will shoot the code , correct? Thanks!!!
JaredKaragen
Re: DIY ecu tester?
« Reply #19 on: September 06, 2012, 12:14:02 AM »
I have the moates model.  Worth every fucking penny!
walter
Re: DIY ecu tester?
« Reply #20 on: September 14, 2012, 09:24:00 PM »
Did it, tell me what do you think.
ECU 1 , stock ecu, checked it works pluged to the car, not cel. blinks but led light very low.
https://www.youtube.com/watch?v=wfK8d6wu1SQ
ECU 2, chipped but J1 cutted, i connect J1 and samething happends , but it hasnt chip lol. doesnt blink , just led light very low always.
https://www.youtube.com/watch?v=zd78stDKMco
ECU 3, chipped, solid cel.
https://www.youtube.com/watch?v=f1V1PymNqCo
walter
Re: DIY ecu tester?
« Reply #21 on: October 03, 2012, 05:00:09 PM »
finally i made it better, i will shoot some pics soon, idk how reliable will be this because i tested a ecu i chipped yesterday and found this problem.
http://www.realhomemadeturbo.com/forum/index.php/topic,20307.0.html
but , according tester , ecu is OK.  :-\
JaredKaragen
Re: DIY ecu tester?
« Reply #22 on: October 14, 2012, 04:41:33 AM »
add a resistor to the CEL circuit if your using an LED;  it doesnt get pulled down enough and lights up dim.
damned LED's are efficient these days.
My moates engine sim always has dim lit LED's.
walter
Re: DIY ecu tester?
« Reply #23 on: October 14, 2012, 05:13:20 AM »
i dont know how efficient is this tester...it says my ecu is good but when i connect to the car is throwing solid cel.. :noel:
P.D already ordered a moates engine simu..
