Author Topic: explain loosing power with rerouted wastegate pipe.  (Read 26540 times)
« on: April 24, 2009, 11:24:30 PM »
I am shoping for some more eg parts (fuck you xenocron your not getting any of my money) but tell me about wastegates, open vs closed loop, I'm being told you loose power with it routed back into the exhaust but why unless your exhaust was too small.
Re: explain loosing power with rerouted wastegate pipe.
« Reply #1 on: April 24, 2009, 11:31:20 PM »
It all depends. If you dump the EWG under the engine bay and the air filter picks up some of it, then you loose power pulling because the % of O2 going in the motor goes down. Automatic EGR.
On the other hand, recirculating the gasses is bad as that ups the mass flow rate going through the exhaust, ups the backpressure, etc. Also reintroducing the stream of gases from the EWG smoothly can be challenging as well.
That said, I like quiet shit so mine dumps in at a 90* angle 5" from the turbo. Not ideal by any means, but works. I'll redo it one day I guess.
« Reply #2 on: April 24, 2009, 11:46:18 PM »
Thats basically what I was thinking, I cant see a car with 3 or 3.5 or 4inch exhaust being much of a deal though. I planed on going back to the firewall area with it and merging there at a gentle angle.
BoostForLife
« Reply #3 on: April 24, 2009, 11:52:20 PM »
Do you not like the sound of an open waste-gate? Put a mini-muffler on it. :noel:
« Reply #4 on: April 24, 2009, 11:53:41 PM »
Yeap. I want to put a piece of 4" pie cut love coming off the turbine and combine the WG's flow down below the car. But that's easier said than done on a miata.
« Reply #5 on: April 25, 2009, 12:00:51 AM »
I dont want the smell or the sound
I could see that, lol
« Reply #6 on: April 25, 2009, 12:03:17 AM »
Seriously, it was pure hell making a 3" pipe fit and be removable without having to drop the rest of the exhaust or pull the turbo. V-band will be welded to the turbine next time that shit comes off. I don't care how much they cost; they're a bargain at any price.
BoostForLife
« Reply #7 on: April 25, 2009, 12:21:52 AM »
V-bands are awesome, much faster and easier to take things off.
stealthiskey
« Reply #8 on: April 25, 2009, 08:51:58 AM »
V-bands are awesome, much faster and easier to steal things off.
fixed
« Reply #9 on: April 25, 2009, 01:09:47 PM »
Or a megaphone
89hatchsir
« Reply #10 on: April 25, 2009, 01:24:53 PM »
I've never seen anyone run a megaphone on their dump pipe. Looks good but hows it sound?
Find out where lexi Belle lives I wanna rape her. and by rape I mean sweet gentle love....of the ass....and mouth
« Reply #11 on: April 25, 2009, 02:29:25 PM »
Or a megaphone
you are a animal  O0
« Reply #12 on: April 25, 2009, 02:32:00 PM »
Havent run them yet.
And it was Dave @ Passenger's idea
he is the crazy one. I like the idea though. He said it keeps them quieter apparently?
« Reply #13 on: April 25, 2009, 02:43:53 PM »
« Reply #14 on: April 25, 2009, 02:48:14 PM »
Strange but true, I've done back to back testing with my DB meter.
« Reply #15 on: April 25, 2009, 02:49:48 PM »
Try testing it vs. a straight piece of pipe? I can see it changing the frequency, but not the actual dB.
« Reply #16 on: April 25, 2009, 02:56:59 PM »
Yes vs 1.5" straight tube, difference was only around 8-12DB IIRC, I'll have to look through my notes.
Aero
    • Turbotalk.org
« Reply #17 on: April 25, 2009, 04:03:02 PM »
That is a fairly noticable change to the ear though if thats true.
« Reply #18 on: April 30, 2009, 12:53:28 PM »
Megaphones amp your voice because they direct it all one way, the dump is already dumping noise in one direction so the megaphone probably widens the path. And 10dB is half as loud.
I prefer to recirculate it on a street car. My current setup has a 3" turbo-back to the gas tank, which goes one way to an e-cutout and one way to the stock muffler. If you thought a bone-stock Civic was quiet... Personally I think people (fabricators) just get lazy and make those claims. The people that do recirc put it very close the turbine outlet and don't give it much of an angle. They'll spend a lot on a cool manifold, but completely forget a dump tube should merge as smooth as their manifold. My HMT setup hits it with a ~60* roughly 20" after the turbine outlet.
speedjunky01
« Reply #19 on: April 30, 2009, 01:20:39 PM »
pic of said rerouting?
here is how i did mine but never made it to a running car to test it out, will be on the 4dr in a week or two.
i think ill redo the DP make it AC and PS friendly but it will be hard to plug it back in far down the DP since the turbo will be the other way
« Reply #20 on: April 30, 2009, 02:36:08 PM »
guy i know whose been making exhausts for like 30 years told me that if you go from a small pipe and flare it out larger it removes the raspyness and quiets it down, didnt believe him untill he put a strait pipe up to my exhaust and revved it (raspy as hell) and then he expanded it on his bender and stuck it back up and there was no raspyness whatsoever.
