Author Topic: d16y8 and d16y5 heads  (Read 30937 times)
AbaZ
  • Out of retirement
    • R-HMT
« on: April 28, 2009, 11:21:07 AM »
Dont feel like doing research, can a y8 cam be swapped in a y5 head? or is it just completely different, I have a y5 longblock sitting in my garage with a rod ejected out of the pan. Just want to know info about it. Are the intake manis the same? look similar.
Re: d16y8 and d16y5 heads
« Reply #1 on: April 28, 2009, 12:06:22 PM »
i believe y5 and y8 rocker assembly are totally different but you can swap out the whole rocker assembly with cam around.   the y5 also uses roller rockers. rock the y5 jeff..
the y5 intake manifold may be the same as a z6.
'96-'00 honda civic hx d16y5 1.6l sohc vtec-e
Roller rockers
17mm roller cam follower
Intake rocker ratio: 1.658
Exhaust rocker ratio: 1.928
Intake lobe total lift: .193"
Exhaust lobe total lift: .166"
I&E Total valve lift: .320"
« Last Edit: April 28, 2009, 12:15:32 PM by ApexSilver06MR »
DreaMeR
« Reply #2 on: April 28, 2009, 12:08:49 PM »
yeah but from what Ive heard is you can fit the y8 cam in there
« Reply #3 on: April 28, 2009, 12:13:07 PM »
wow y5 rockers are roller.
Would they interchange with any other v-tec rocker assymblies? ;D
« Reply #4 on: April 28, 2009, 12:16:42 PM »
i would ask turbo4life.  he has messed around with all of that y5 shizzle
« Reply #5 on: April 28, 2009, 01:45:50 PM »
99 percent sure you cant swap camshafts a buddy of mine got really deep into these heads a couple years back and he had a camshaft reground by crower just for the y5 head.
The manifolds d16y8/y5 I know are identical minus the fact that the d16y5 has a egr port/egr valve on them.
Loserkidwac
« Reply #6 on: April 28, 2009, 03:03:14 PM »
Port sizes the same? I know the z1 head compared to other D series has much smaler ports along with the roller rockers like the y5...Im gonna say the cams won't swap, believe the profiles a lot different because of the use of roller rockers
2002 BMW 530i Sport
1992 Mazda Miata
1998 K2500 454
« Reply #7 on: April 28, 2009, 03:08:50 PM »
Y5 heads ports are just like other vtec model that make solid power. The only thing holding that motor back is that uber small camshaft
crx-ecutioner313
« Reply #8 on: May 12, 2009, 12:38:28 PM »
will a d16z6 head fit on a d15b7 bottom
« Reply #9 on: May 12, 2009, 01:30:25 PM »
Why are you asking this when it is already been done on your car?
« Reply #10 on: May 12, 2009, 01:56:13 PM »
No its never been done....     :?:
« Reply #11 on: May 13, 2009, 01:47:16 AM »
Stock HX head
A6 block with LS rods, GX pistons
Orange Chicken
Fuck all of you
« Last Edit: May 13, 2009, 01:51:16 AM by Joseph Davis »
« Reply #12 on: May 13, 2009, 03:37:04 AM »
Damn impressive
