Author Topic: ls cams  (Read 30268 times)
fuse
ls cams
« on: April 28, 2009, 08:08:50 PM »
Ok I am dicking with a ls now. I have a to pick from b18a cams, b18b cams and b20 cams (I am a pack rat). This is a n/a build on a buget. I also have b20 springs and .060 shims. I want more mid to top end on this build.
My question is what cams should I use and what rpm should I set my rev limit? What have U all reved a b18b safely too?
The b18b and b20 have about the same lift but the b20s look to have more duration. The b20 springs have less miles (30K) then the b18b and measure a bit longer.
Thanks glad I found the real hmt.
Re: ls cams
« Reply #1 on: April 28, 2009, 08:16:43 PM »
i have my dirty b20 (in in the list of build threads) revving to 6k.  My brother is currently using the car and he gets kind of crazy with it but i had to limit his shit...
i usually have it set to approx 7200
fuse
Re: ls cams
« Reply #2 on: April 28, 2009, 08:24:48 PM »
I was wanting to use b20 cams and push it to 8000 8500 is this a bad idea? LOL. What will brake first?
Re: ls cams
« Reply #3 on: April 28, 2009, 08:26:19 PM »
youre not going to make any power at the point so why try?
BoostForLife
Re: ls cams
« Reply #4 on: April 28, 2009, 08:28:45 PM »
You can rev it all you want, but you'll have no power up there and taking the motor past the limit of it's desing. Have chris port the shit out of your head/manifold/buy his throttle body, upgrade to at least vtec series springs for higher RPMs.
fuse
Re: ls cams
« Reply #5 on: April 28, 2009, 08:32:56 PM »
Head is ported was going to retro fit a bigger tb. K maybe I will just stick to a 7500 just a bit over.
89hatchsir
Re: ls cams
« Reply #6 on: April 28, 2009, 08:53:22 PM »
Without aftermarket cams, you won't make any power. It will feel like it fell on it's face. I had a chipped ecu with my ls swap, no rev limiter, there was nothing when I  revved it to 7500. No power up there.
Find out where lexi Belle lives I wanna rape her. and by rape I mean sweet gentle love....of the ass....and mouth
Re: ls cams
« Reply #7 on: April 28, 2009, 09:03:31 PM »
What Vtec springs can you use in a LS head  ???
Re: ls cams
« Reply #8 on: April 28, 2009, 09:21:22 PM »
Max power and torque are at about 6300rpm, why do you want to rev it to 8000? Buy aftermarket cam and some good spring to keep your part in place. Otherwise 7000-7200 max.
N/A all is worthless anyway.
snarf
Re: ls cams
« Reply #9 on: April 30, 2009, 02:20:56 PM »
Forget the cams for now.  Think pistons!
Re: ls cams
« Reply #10 on: April 30, 2009, 02:25:55 PM »
yes everyone is right so far.
i had a beat ls and did the how high does this go test(chipped ecu w/ unknown chip) well i made it to about 8500 and it wouldn't go any higher not rev limit just stopped revving.
So yeah power drops off fast.
Re: ls cams
« Reply #11 on: April 30, 2009, 03:43:15 PM »
send stock cams to delta for a regrind and be done with it
Re: ls cams
« Reply #12 on: April 30, 2009, 05:13:11 PM »
stock ls cams
stock manifold
stock throttle body
and you want to call it an all motor build. Its more like a stock motor.
Re: ls cams
« Reply #13 on: April 30, 2009, 05:14:49 PM »
USDM B18A1 (’90-’93)     Stock     270°/276°     186°/190°     .392"/.380"     9.95/9.65
   USDM B18B1 (’94-’00)    Stock    274°/278°    183°/184°    .393"/.380"    9.98/9.65
   USDM B20B (’97-’98)    Stock    278°/276°    190°/194°    .397"/.382"    10.08/9.70
Re: ls cams
« Reply #14 on: April 30, 2009, 09:44:36 PM »
stock ls cams
stock manifold
stock throttle body
LOL
fuse
Re: ls cams
« Reply #15 on: April 30, 2009, 10:38:27 PM »
Thanks that is what I am looking for so b20 a bit better but not much. Ok. How much to re grind.
« Last Edit: April 30, 2009, 10:42:53 PM by fuse »
Re: ls cams
« Reply #16 on: May 04, 2009, 01:49:00 AM »
call and find out ain't gonna do all the work for ya
Re: ls cams
« Reply #17 on: May 04, 2009, 11:28:51 AM »
All you need to know about budget LS builds:
- LS cams suck, run the B20s, but only if they are free.  The gain in performance (over anything but autotragic cams) is not significant.  Crower 404s are your friend, do not go any smaller it's pointless either NA or boosted and wastes your money on a worthless cam.  I unofficially like the Brian Crower stage 3 (longer duration, less lift than 404), it will become official after I strap this car to the dyno and obtain clarification.
- Avoid 90-91 LS "small port" heads.  They fucking suck.
- If you have $3, get a set of B20A/B21A intake valves (33mm) and have the seats in your head replaced to suit them.  Poor man's P8R.  If you have more than $3 just buy Ferrea, but this is RHMT bitch you can barely afford $3.  Also, B20A/B21A inner valvesprings are your friends with 33mm intakes, while still on stock cams.
- LS rockers don't like to rev, mkay?  If the rocker pops out while adjusting valves, replace it and it's ball seat that screws into the head with one that doesn't.  Some people get away with 8500 rpms but I cut them off at 8K unless the owner understands the risk.  Usually a rocker pops off and you just reassemble, sometimes it gets in somewhere important and shit gets itself fucked.
I wasn't impressed by their 272s.  159 whp 143 wtq on a stock B20Z with Skank9 IM and big tube header, the flow up top just fell off where even wussy 402s don't.  I never dyno'd the car (or any other B20B/Z) on stock cams so maybe there's a nice bump in midrange which makes for a lot of driveability... which you get out of a bigger cam, anyway, with how badly stock cams suck.
Re: ls cams
« Reply #18 on: May 04, 2009, 12:18:27 PM »
Hybrid site still has a bunch of dyno's with stock b20b's/z's but the motors all got nice headers,bored throttle bodies etc but all on stock cams
Re: ls cams
« Reply #19 on: May 04, 2009, 12:24:15 PM »
orly?
Time to look that shit up, I'm curious.
Re: ls cams
« Reply #20 on: May 04, 2009, 12:41:36 PM »
http://hybrid.honda-perf.org/tech/b20/b20dyno.html#dyno1
amazing hybrid honda still is a top search on search engines even though the site has been dead for 5+ years
fuse
Re: ls cams
« Reply #21 on: May 04, 2009, 08:21:22 PM »
Thanks I will see what I can fine and ya the b20 cams are free. Yes I am a broke ass. lol Don’t like the price of regrinds (200$+).
B20a b21a cams will not fit will thy? I may have my hands on a b21 head free. I can only nab the springs and valves? Head looks way different.
« Last Edit: May 04, 2009, 08:32:25 PM by fuse »
Re: ls cams
« Reply #22 on: May 04, 2009, 09:53:51 PM »
The valve stem OD, and valve overall lengths, are identical.  You really need a bigger seat installed... you might find a machinist who'll thin the existing seat (make it's ID bigger) for more flow, but if it gets too thin the seat drops which is basically that same as a valve dropping.  Your perfectly good shit goes bye bye.
Re: ls cams
« Reply #23 on: May 04, 2009, 11:24:21 PM »
200 for regrinds is very cheap delta is the cheapest in the country
hotrex
Re: ls cams
« Reply #24 on: May 04, 2009, 11:29:54 PM »
i paid 319 for my brian crower stg 2 turbo shits
lets face it 319 aint shit
Re: ls cams
« Reply #25 on: May 04, 2009, 11:46:01 PM »
No kidding
Re: ls cams
« Reply #26 on: May 05, 2009, 01:16:04 AM »
LOL Joseph funny story here um and a true story. I tuned a guys b20 swapped with turbo da integra car ran great drove smooth real nice car I enjoyed tuning it.
  He calls me to come over a month or so later and he's got a 90 LS head swapped onto it said he heard somewhere ls heads are better  ::)  Gotta love people sometimes.
Re: ls cams
« Reply #27 on: May 05, 2009, 01:49:03 AM »
Well 99 percent of b20b's came with p75 ls heads. p8r heads are pretty damn rare and I have one Im keeping just in case I ever get the itch for a b20 non vtec build.
hotrex
Re: ls cams
« Reply #28 on: May 06, 2009, 04:03:17 PM »
go ahead and sell me that p8r head chris..   cash in hand
Re: ls cams
« Reply #29 on: May 06, 2009, 04:39:24 PM »
shoot me an offer
