Pages: 1 ... 4 5 [6] 7 8 ... 26   Go Down
Author Topic: 10/4 cracked sleeve and eye meltage pics and vids... ANUS  (Read 492130 times)
QikEnuF
Looks like good work, darknog.  You seemed depressed on AIM you sandbaggin son of a bitch
looks like a solid setup. update me on the spool time with that split pulse manifold. it should help a lot.
hx35 =  O0 mans GT35R
hotrex
hx35w was a 10th of the cost of the turbo i almost bought...
when i sleeve the block next winter itll be gettin something hefty
Call me when you fire it. Ill grab Noel and swing out.
hotrex
looking like friday might be the day we fire it.   i finished all the wiring tonight, tomorrow is the catch can install. put the radiator back in it replace my led cel for a reg light bulb type and once over the car to make sure its all kosher
well def call u guys
I don't see how you can work on a car and then have to check if it's kosher.  And I mean that in the most purilent manner possible.   :noel:
hotrex
just make sure all the ts are crossed and Is are dotted.   i know its all right
hotrex
im buyin jd a plane ticket
hotrex
ill see wat i can do
AJxr
  • i aint ur buddy pal
i hope this bitch is running
90 hatch
Its running. Motor sounds good. Has good oil pressure. A few things to button up and it can be street tuned.
hotrex
amen for that.     :noel:
Lol not caught on fire but ate his cam caps. Looks like its time for a GSargh head.
nothing like being broke down on the side of a highway with dicks on your car.
hope he tows it home himself
wtf? man you have terrible luck
luck or karma?
hotrex
no big deal. i had the car out last night for the first time and it felt great.. was running smooth as hellk then this went down on the highway.
no biggie. blocks fine and im picking up a gsr head and studs tomorrow off a friend.
so....  looks liuke this upcoming weekend itll be a ls/vtec turbo afterall.  more power to mne... literally.
AWDstylez
omg...
I saw that "needs a valve adjustment" post in the other thread and immediately thought "that motor is toast."
Any idea what caused it?
Timing belt completely delaminated.  Sell me the LS stuff for 59 cents, Joshrex.
hotrex
so what coulda caused this
Re: 2009 HOTREX 66% THROTTLE BUILD: 5/25 update action.. johnny rips choda
« Reply #173 on: June 01, 2009, 12:10:01 AM »
what you need that stuff for jd?  research?
« Reply #174 on: June 01, 2009, 12:12:12 AM »
Hotrex wants almighty V-Tech, so I'll take his perfectly good shit for 59 cents.  What other reason could I have?
« Reply #175 on: June 01, 2009, 12:23:52 AM »
hell if i know, i've still got a set of shocks somewhere in my attic i was going to donate to you
« Reply #176 on: June 01, 2009, 12:31:05 AM »
I bought the load cell.  The next free time I have I go to the scrapyard and buy the steel to build the dyno.
90boostdaccord
« Reply #177 on: June 01, 2009, 04:17:48 PM »
you can buy it as a souvenier(sp?)
he has to start selling them from all his failed builds so he can finally get something to run right.  ;)
« Reply #178 on: June 01, 2009, 04:23:51 PM »
scrap prices are up a cunt hair from last month
$4/100 lbs steel  and  $.50/lb clean aluminum
AbaZ
  • Out of retirement
    • R-HMT
« Reply #179 on: June 01, 2009, 05:48:22 PM »
cool build josh... Shitty luck on the head. Hopefully all goes welll with the gsr head.
Pages: 1 ... 4 5 [6] 7 8 ... 26   Go Up
