Author Topic: bad fuel injector?  (Read 17179 times)
SlowVrT
  • vw status
bad fuel injector?
« on: May 01, 2009, 11:36:41 AM »
Ok, wanna see if anyone could help with this,car is a 94 vw jetta with vr6, i was driving my car, was driving normal and all of a sudden my car started missing, i went home changed out my coil pack, because i thought it was that, changed it and was doing the same thing, my plugs have less then a 1000 miles, and i kno my wires are good,  the way my intake manifold is i can only reach one fuel injector, and ive had trouble outta this injector for leaking, the injectors also have less then 1000 miles, but anyways when i unplug the injector the car still runs the same, think it could be the injector?
94 Jetta VrT
13.29 @ 108....street tires/8psi
SgtB
Re: bad fuel injector?
« Reply #1 on: May 01, 2009, 12:36:32 PM »
It could be your lack of proper punctuation and capitalization. Take two seconds to explain it to me in a way that doesn't cross my eyes, and you'll get help quicker.
SlowVrT
  • vw status
« Reply #2 on: May 01, 2009, 03:10:13 PM »
My car is missing I unplugged a injector one I have had trouble with for leaking, and it didnt change the way the car was running so im thinking injector is bad.....     that better?
94 Jetta VrT
« Reply #3 on: May 01, 2009, 03:35:00 PM »
No.
« Reply #4 on: May 01, 2009, 03:58:44 PM »
VR6 eat spark plug wires.  Check continuity across that wire and compare it to the others.
When you fix it, sell your car and get something that doesnt suck donkey cock.
SlowVrT
  • vw status
« Reply #5 on: May 01, 2009, 04:04:54 PM »
im good im not gonna sell my car i love my vw, coming from hondas to this is so much better, all my wires were just replaced not to long ago, i had the car running, and unplugged one wire at a time and it still sounded the same
94 Jetta VrT
« Reply #6 on: May 01, 2009, 06:23:39 PM »
Dude just swap the wire on the dead cyl with another and see if the miss moves.  Humor me.  Also look at your plug on that cyl.  Just cause the wires are new doesnt mean you dont have a bad one.
While you have the plug out, with it in the wire lay it on a surface it can be grounded, and get your mom/sister/girlfriend to crank it for you.  Spark/no spark.  If you have spark, check fuel.  Check compression, etc etc.
Fuel, air, spark, compression.  Your dead cyl isnt getting one of them.
Roll eyes smiley.
On a side note, I smoked a modded Vr6 mk3 in the twistes today in my stock mk5 2.0t Jetta.  I lol because my Jetta is slow.
« Last Edit: May 01, 2009, 06:27:05 PM by Robb »
« Reply #7 on: May 02, 2009, 10:45:15 AM »
On that note...
