Author Topic: 14point7 idash. Discuss.  (Read 22245 times)
NoPistons!
« on: October 27, 2012, 02:08:34 PM »
http://www.14point7.com/
As far as i know this is a brand new product.   They come in basic, single lambda and dual lambda. Prices are on their page.  I love the future.  =D
Key Features
Single or Dual Lambda Configurations
Wifi Connectivity
Embedded Webserver technology compatible with all mobile devices
HTML, HTML5, and Adobe Flash interface
Real-Time display of 25 performance metrics on any mobile device
Built in RPM pickup
Built in dual axis accelerometer
Internal Memory for 1.5 hours of datalog storage @ 10 samples per second
Longest warranty in industry, 2 years
Inputs
Single or Dual Lambda option
8x Exhaust Gas Temperature ; 0[C] to 2500[F], 0[C] to 1400[C]
1x Engine RPM; 0[RPM] to 10000[RPM]
1x Shaft RPM; 0[RPM] to 10000[RPM]
2x Boost/Vaccum; 0[PSI] to 44[PSI], -30[Hg] to 88[Hg]
1x Fluid Temperature; 0[F] to 300[F], 0[C] to 150[C]
2x Intake Air Temperature; 0[F] to 250[F], 0[C] to 125[C]
1x Fuel Pressure; 0[Hg] to 250[Hg], 0 to 150[PSI]
1x Oil Pressure; 0[Hg] to 250[Hg], 0 to 150[PSI]
1x Acceleration G Force; -4[g] to [4]g
1x Cornering G Force; -4[g] to [4]g
2x Analog Inputs; 0[v] to 5[v]
iDash Basic includes the following items
1x iDash unit
1x Wireless router (iDash supplies power to the router)
1x 4ft 4 conductor 18 AWG iDash power cable
1x 2ft 2 conductor 20 AWG router power cable (connects to iDash for power)
1x 4ft ethernet cable
1x 1A replacement fuse
1x Software CD
iDash Single Lambda includes the following items
1x iDash unit
1x Lambda controller module installed into iDash
1x Bosch LSU 4.2 Lambda sensor
1x 8ft 6 conductor 18 AWG Lambda Cable
1x 10A replacement fuse
1x O2 bung
1x Software CD
iDash Dual Lambda includes the following items
1x iDash unit
2x Lambda controller module installed into iDash
2x Bosch LSU 4.2 Lambda sensor
2x 8ft 6 conductor 18 AWG Lambda Cable
2x 10A replacement fuse
2x O2 bung
1x Software CD
« Last Edit: October 27, 2012, 02:10:08 PM by NoPistons! »
Re: 14point7 idash. Discuss.
« Reply #1 on: October 27, 2012, 02:41:08 PM »
I use the SLC PP1, now replace with SLC PP2, seems to work well.
And Now Installation How-to of my 14point7 Pure Plus SLC
First read the instructions.
Look at your power (4pin w/ Orange, Red, Black, Brown wire) connector and figure where you want to get your 12v power and ground.
I used this Diagram
Hook up the red to the constant hot when key on
Put the fuses in the holders make sure you use the right size to the circuit based on the instructions.
Also make sure the spring tension in the holders are good.
I had to modify mine to get good contacts or I would lose voltage intermittently.
Now hook up the 6pin connector and route through the firewall to hook up to WB O2.
BTW the replacement O2 is  Bosch p/n 14017 approx. $55 locally.
The Display has been moved to where the clock would be in the dash in March '11. (idea from Apex.)
Figure out where you want the display.
After everything is hooked up.
The display should look like this.
Then load up the SLC program on your lappy.
And open up the program.
I have the blue now where the clock would be in the dash.  :noel:
NoPistons!
« Reply #2 on: October 29, 2012, 02:33:32 PM »
They make good products.  This one is a bit different though.
My order on vitals/management put me over the cost of the idash and that's even with buying a used tablet or ipod/iphone/etc.....  Kinda kicking myself on that one.   idash is ballin on a budget for people who do not want to run an oem cluster.
Just throwing the idash out there as a budget minded alternative to a custom or stackstackstack setup.  Using all autometer stuff a full cluster replacement will run well up past $500.
« Reply #3 on: October 29, 2012, 03:38:10 PM »
Maybe I'm confused, what does this thing display on? I want to lose the cluster on my ef hatch one day and my crx very soon.
« Reply #4 on: October 29, 2012, 03:58:59 PM »
« Reply #5 on: October 29, 2012, 05:55:49 PM »
« Reply #6 on: October 29, 2012, 05:57:24 PM »
Pay especial attention to the avatar while reading that.
« Reply #7 on: October 29, 2012, 06:04:09 PM »
Dr.Who reference?
« Reply #8 on: October 29, 2012, 06:41:39 PM »
Mostly the facial expression while the text is scrolling - perfection.
« Reply #9 on: October 29, 2012, 07:05:00 PM »
to hell with using a mobile device as a gauge cluster. ill just log with neptune if i want to use a mobile device.
oh yea, JD
« Reply #10 on: October 29, 2012, 07:40:50 PM »
« Reply #11 on: October 29, 2012, 07:48:05 PM »
NoPistons!
« Reply #12 on: December 31, 2012, 01:46:11 PM »
It's always nice when things are as funny as they are creepy.
