Author Topic: faggy vtec problems  (Read 19987 times)
2slow
faggy vtec problems
« on: November 01, 2012, 04:15:20 PM »
92 prelude with a edm f20b dohc vtec. I'm getting a code 22 which is the vtec pressure sensor. I tried the trick of bypassing the sensor but I just gave me a vtec solenoid code 21. Is this engine supposed to have a single wire vtec solenoid? Also this is on a usdm p13 ecu.
Re: faggy vtec problems
« Reply #1 on: November 01, 2012, 05:48:50 PM »
Look at the solenoid, most likely you have junk in the gasket/filter.  :noel:
As for the rest not completely sure.  :-\
2slow
« Reply #2 on: November 01, 2012, 11:00:20 PM »
Cool ill check that out tomorrow and report back. This is my first problem with vtec engaging and also my first gaylude, so all I can go by is the retarded prelude forums which all the thread end up people just asking about how much swaps cost
« Reply #3 on: November 01, 2012, 11:06:51 PM »
If you can define exactly when the code pops I can help.  But, agreed, check solenoid screen first.
« Reply #4 on: November 03, 2012, 12:27:55 AM »
How much did your swap cost?
2slow
« Reply #5 on: November 04, 2012, 11:39:46 PM »
I bought it from a guy in the fluffy crew for 41 cheese burgers. On a side not vtec seems to be engaging even with the code 22
