Author Topic: gsr crx burning oil very badly... boost it?  (Read 29595 times)
buk9tp
« on: May 07, 2009, 04:52:56 AM »
about 3 quarts a week!
compression is still good... trying to get a leak down test going here as soon as i can find someone with the right equipment....
car doesnt smoke.... it runs fine... idk.. this shit sucks.. buk cant afford a fucking rebuild :( nor can he afford another fucking motor...
basically i need to add about a quart every other day...
Re: gsr crx burning oil very badly... boost it?
« Reply #1 on: May 07, 2009, 04:54:38 AM »
is there a visible leak?
buk9tp
« Reply #2 on: May 07, 2009, 04:57:05 AM »
no leaks anywhere!!! car/ground/motor/oil pan everything clean
i park in the same spot every single day...
i just realized i dont think it did this when i ran my p75 ecu.....
so could vtec be causing it to eat oil lol
buk9tp
« Reply #3 on: May 07, 2009, 04:58:22 AM »
no leaks and no smoke!
turbo4life
« Reply #4 on: May 07, 2009, 05:40:05 AM »
h-t says vtec uses oil thats just how it works :somb:
End the fake food.
« Reply #5 on: May 07, 2009, 09:04:05 AM »
My buddy said the same thing about his Oil consuming Spec V sentra.  No smoke no leaks but when i followed him one day sure enough whenever he'd give it like anything over about 50% throttle it would puff.  Nice and black too, Back of the car was never oily or anything though.  I'd have someone follow you around for a bit and see if it is smoking only under load or something.
I mean that shit is going somewhere.  :-\ good luck with it.
« Reply #6 on: May 07, 2009, 09:16:02 AM »
Sweet, and I thought my A6 was bad burning the same amount of oil  :noel:
Definitely some visible smoke though.  I spread cancer at every intersection.
drivin96
« Reply #7 on: May 07, 2009, 11:26:58 AM »
yea my oil pan leaks a lil and when my v-tec kicks i smoke, 1-2 bad 3-5 nothin really usin about a 1Q each week and a can of breakcleaner every two weeks to clean the oil spotsin the driveway
Honda-Tech
« Reply #8 on: May 07, 2009, 11:46:10 AM »
Check your PCV valve.
Run a little seafoam through it to unstick the oil control rings.
« Reply #9 on: May 07, 2009, 11:53:00 AM »
It seems we are very near the zombie apocolypse.  Honda-Tech has tech....
« Reply #10 on: May 07, 2009, 12:37:55 PM »
lol nah the other account that dude ueses i bet got banned lol.
« Reply #11 on: May 07, 2009, 02:13:52 PM »
Motor is tired if its burning through that much oil. what were your compression #'s
If you say in the 180's the motor is worn out like every other usdm gsr motor
« Reply #12 on: May 07, 2009, 02:37:58 PM »
If that shit isn't leaking, I don't see how it's not smoking.  Mine smokes like whoa and uses the same amount of oil per week.  When I come to a stop, if the wind is right, a cloud of burning oil drifts by my window  :noel:
« Reply #13 on: May 07, 2009, 03:28:51 PM »
One of my zc's used about a quart of oil a month about a 1000 miles and it smoked like a chimney at wot above 4500 rpm's
The oil has to be burned off it just doesnt disappear
You sure you even have the right dipstick?
« Reply #14 on: May 07, 2009, 08:58:36 PM »
If it burns 3qts of oil the back bumper/hatch would be covered in Oil  :?:
BoostForLife
« Reply #15 on: May 07, 2009, 09:47:17 PM »
something is obviously fucked up. Does it have blow-by in PCV system?
d-rail
« Reply #16 on: May 07, 2009, 10:28:22 PM »
The swine flu is attacking your motor! LOOK OUT!
nig nog
  • rhmt equalizer
« Reply #17 on: May 10, 2009, 11:02:09 AM »
this thread smells of unwashed muslom cock.
1991 F-150 351W E-cam hedders
1988 Merkur XR4ti .50 T3/T4
2003 S2000
SgtB
« Reply #18 on: May 10, 2009, 01:39:54 PM »
The valve stem seals like to shit the bed on GSR's. Vtec burns oil like crazy when that happens.
« Reply #19 on: May 10, 2009, 01:42:06 PM »
YUP!!!!!!!!!!!!!!!
89shithatch
« Reply #20 on: May 10, 2009, 05:39:03 PM »
at least you never have to change your oil. constant 24 hr oil change. spin a new filter one once in a while and give her.
« Reply #21 on: May 10, 2009, 05:45:03 PM »
If the cars does burn that much oil the car will barely move on its own power
« Reply #22 on: May 10, 2009, 07:56:42 PM »
Someone's been siphoning off your oil when you're at your boyfriend's house.
« Reply #23 on: May 11, 2009, 04:14:58 AM »
do you crack vtec alot? the vtec solenoid requires oil to engage, thats where all the oil is going to. everytime you hit vtec is uses a little oil, thats why people say vtec motors burn oil. theres always a downside to amazing techmology.
« Reply #24 on: May 11, 2009, 10:39:47 AM »
Are you serious or just retarded?
« Reply #25 on: May 11, 2009, 11:49:09 AM »
Im gona say retarded....lol
« Reply #26 on: May 11, 2009, 12:16:41 PM »
What the fuck?
I guess you have just found the magic of VTAK.
crx-ecutioner313
« Reply #27 on: May 12, 2009, 12:36:04 PM »
dont feel bad about the oil my paseo has 400k on her and uses 2 qts a week but i still drive it hell i would put a 80 shot on it if i had it, but my 88 crx si has 30k on its engine and has a oil leak also but mines a gasket
« Reply #28 on: May 13, 2009, 01:16:03 AM »
U not smart duhhhhh  :somb:
« Reply #29 on: May 13, 2009, 08:53:50 AM »
Don't mock, guys.  Corey drives a Mustang and is therefore smarter than us and knows about these things.
