Author Topic: antilag crome gold question  (Read 11892 times)
walter
« on: April 26, 2013, 08:25:39 PM »
im having a problem setting standstill boost generator, ignition retard works good, set to 30, but fuel enrichment doesnt, tried 200-500-1000-1200,etc, it get too lean still... any idea about this? what is your setting for this? using 1.6.5.
Thanks.
clwtwizted
  • Fuck You!!!
Re: antilag crome gold question
« Reply #1 on: April 27, 2013, 12:03:48 AM »
Crome uses fuel cut so its going to say lean because its cutting the fuel to stop the car from reving up higher.
walter
« Reply #2 on: April 27, 2013, 06:15:17 AM »
wow really? i readed somewhere that is needed to enrich since it's readying boost..
« Reply #3 on: April 27, 2013, 10:20:00 AM »
Walter,
Check this thread http://www.onecamonly.com/showthread.php?t=2994
It was posted by a member from here.
There is a vid on there too, but it just show some flame out down pipe at 40sec. in.  :noel:
And here is a RHMT link http://www.realhomemadeturbo.com/forum/index.php/topic,4216.msg65831.html#msg65831  :noel:
« Last Edit: April 27, 2013, 10:30:15 AM by 92CXyD »
walter
« Reply #4 on: April 27, 2013, 03:50:48 PM »
that's using crome free, im using crome gold.  :-\ Im just worried about when it generate boost engine is too lean..
« Reply #5 on: April 27, 2013, 06:05:21 PM »
Antilag is timing, and depending on seetings, adding fuel. Different than a limniter, theres not really a CUT, in addition yanking 6-7 degrees static, setting reset to about 250RPM and adding healthy fuel value +4"DP and short exhaust = Scareing the fucking shit out of people... And making wastegate standing still.
walter
« Reply #6 on: April 27, 2013, 07:16:13 PM »
dont get what you means and dont reply my question , anyway if it's right the second reply , it's ok then.  :noel:
