Author Topic: Cheap 4 barrel throttlebody?  (Read 15485 times)
« on: May 17, 2013, 08:41:50 AM »
I keep kicking around the idea of putting a small turbo on my truck since I can't afford the 6bt for a while. Anyone know of any cheap 4 barrel TB's out there? I guess I could use an elbow and one big TB. Trying to keep this simple and cheap. Truck is currently carb'd with an edelbrock 600cfm.
If it matters
90 silverado
270hp/350tq 4 bolt main crate motor
Figuring on megasquirt just cause I have always wanted to use one.
Probably some HiProfile injectors.
Re: Cheap 4 barrel throttlebody?
« Reply #2 on: May 17, 2013, 10:04:49 AM »
Gut a carb and mount a Tps to it somehow?
« Reply #3 on: May 17, 2013, 10:31:57 AM »
That's not a bad price on that bbk. Hmmm
I considered using a carb, I have 2 holly 750's. I just didn't want to cobble up a tps setup
« Reply #4 on: May 17, 2013, 11:59:57 AM »
So 5 dollars for a TPS and 30 mins of your time or 250 dollars for a complete setup.
« Reply #5 on: May 17, 2013, 12:53:58 PM »
Just seems like it would look like complete ass. Plus plugging all the fuel holes and everything? Meh. I like the idea of bolting on
« Reply #6 on: May 17, 2013, 02:58:01 PM »
I like the idea of just a single TB on a custom hat thing. stick 4 hi profile injectors in it. and one of those big ass ford style TB's. make it an easy aim at the intercooler and away from turbo.
« Reply #7 on: May 17, 2013, 03:04:36 PM »
kinda like that. but instead of nitrous nozzle you have hi profile injectors.... and a V8.
« Last Edit: May 17, 2013, 03:37:18 PM by 92CXyD »
« Reply #8 on: May 17, 2013, 03:05:52 PM »
Yea, half way through typing I started thinking about making an elbow, put a 90mm mustang tb on it and mount the 4 injectors in the elbow. We will see. I have 2 things in the works to have money in my pocket again. As soon as that happens ill start collecting parts.
« Reply #9 on: May 17, 2013, 03:18:07 PM »
Fixed so I could see it.couldnt copy/paste on my phone for some reason.
« Reply #10 on: May 17, 2013, 03:55:59 PM »
sorry. did it from my phone and didn't check it cuz I'm at work lol.
I think it should be a solid setup.... for a pushrod SBC.
« Reply #11 on: May 17, 2013, 05:56:36 PM »
i use the truck for towing, so i wont be pushing a ton of boost. just want a little extra oomph without ruining the torque. i have a feeling anything else i could do to make power from here on, would just push the torque higher in the rpm range.
« Reply #12 on: May 17, 2013, 06:07:25 PM »
hey, you're the one who said simple and cheap. Not good looking.
« Reply #13 on: May 20, 2013, 09:26:19 PM »
And you already bitch about the coat of gas.
« Reply #14 on: May 20, 2013, 10:01:15 PM »
I'm sure fuel injection would up my mpg a decent amount
