Author Topic: diagnose my shitty integra  (Read 16207 times)
TTC
« on: June 25, 2013, 02:42:50 PM »
So this is the first real issue ive had
2001 non vtak integra LS
Idles mostly ok, if i flip on AC it gets erratic.  Then it starts to want to die and idle hunts.  Sometimes at stop signs with ac or not i try to take off and it just fuckin bogs and dies like a badly tuned megasquirt car. It seems like all ign shuts down not just a few cylinders. I put on some new wires cause I figured why not, I havent done this since I got it. Next is cap and rotor.
It almost seems like the iac is sucking out, but that wouldnt explain why it bogs on accel from low rpm. anyway.
Voltage seems ok at 14, i fiddled with the idle up screw and tossed a check light. I'm pretty sure thats not it.
PS: Can i reset light by disconnecting battery? I could google i guess and figure that out.
Re: diagnose my shitty integra
« Reply #1 on: June 25, 2013, 04:25:23 PM »
Burn it.
Why don't you check the code, because that will tell you exactly what's wrong?
« Reply #2 on: June 25, 2013, 06:14:41 PM »
Burn it.
« Reply #3 on: June 25, 2013, 09:44:53 PM »
I always check grounds before I do anything. Get a set of jumper cables if you dont have any, slap one end on the block, and the other ends on the negative terminal and a clean chassis point, respectively. Anything changes, and your ground sucks, fix it. Nothing changes and you've eliminated the obvious.
TTC
« Reply #4 on: July 05, 2013, 07:22:54 PM »
Clean up grounds and that didn't help.  Only reason it tossed a code is cause I monkeyed around with the idle screw.
« Reply #5 on: July 05, 2013, 08:12:15 PM »
That won't throw a code, shithead.
quadnie
« Reply #6 on: July 16, 2013, 03:38:06 AM »
You never mentioned that this car is stock or not.  If it is stock then we have a world of troubleshooting tips for you.  If it isn't stocked and running a chipped OBD1.... start somewhere else?
