Author Topic: 3 phase motors on single phase  (Read 10714 times)
carkrazed
« on: July 07, 2013, 02:22:10 PM »
I keep blowing the starting capacitor on my compressor and its pissing me off. I have a phase converter and a 5hp 3 phase induction motor laying around. I'm thinking about getting a small VFD and running the compressor with the induction motor.
Anyone ever do anything like this that has some input?
Re: 3 phase motors on single phase
« Reply #1 on: July 07, 2013, 02:28:35 PM »
The Allen Bradley VFDs do 110-->3 phase at a variety of voltages up to either 1.5 or 2hp motors.  Dirty cheap at under $100 on eBay.
I'm not terribly aware of the phase converter market, but my gut feeling has been that larger capacity solutions are expensive.
carkrazed
« Reply #2 on: July 07, 2013, 02:40:24 PM »
So they are essentially an electronic phase converter?
I have a 5hp static phase converter. I could run the motor directly off of it but i'm told that static converters don't like to start compressors. Thats why I figured I could run it through a VFD. I'm not sure if that would lessen the load on the converter or not though.
mandrel-bends
« Reply #4 on: July 07, 2013, 03:46:07 PM »
I've got a newer (2012) 5HP AB vfd running a 3hp grinder out at my house on single phase. The frequency output is not as clean as the output of real 3ph. In our case, the grinder actually vibrates unacceptably running on the vfd as opposed to real 3ph at one of our buildings. Also interesting to note, the VFD did not vibrate the grinder when run from 3PH.
There's a lot of data regarding vfd -> motor vibration. I never had to time to put it on the scope to try to track it down. It definitely not the same as running it on a phase converter.
One article I looked at when analyzing it: http://ftp.betamachinery.com/uploadedFiles/004_-_Knowledge_Center/Technical_Articles/Perplexing%20Variable%20Frequency%20Drive%20Vibration%20Problems.pdf
http://www.mandrelbends.com
« Reply #5 on: July 07, 2013, 04:18:24 PM »
In to see where this goes. I have a big compressor and a 3 phase motor I'd like to combine at home
carkrazed
« Reply #6 on: July 07, 2013, 05:33:33 PM »
Does it vibrate even at low rpm?
I think i'm gonna try out the ching chong vfd. How many hp is the motor you have? There is a 4hp vfd from the same seller for 145.00
« Reply #7 on: July 08, 2013, 08:04:02 AM »
I think it's a 5hp. My pump calls for 5hp.
Looking forward to seeing your results
« Reply #8 on: July 09, 2013, 08:22:56 AM »
Have a surf over Automation Direct's site before going straight eBay china.  They market asian housebrands that are as good as anything else, for less.  If you don't see what you want, with regard to price or features, then try eBay.
« Reply #9 on: July 10, 2013, 10:25:46 AM »
bump for more discussion
« Reply #10 on: July 10, 2013, 02:12:52 PM »
I have no input, just a leach in this thread.
mandrel-bends
« Reply #11 on: July 10, 2013, 03:08:21 PM »
I didnt test low speeds as it doesn't have the needed torque without reaching full speed. From my research, it looks like certain devices have inherent resonances that are amplified badly with these devices.
I remember from my power engineering classes that these things also can push the power factor in both directions (they can alter the reactive power of the motor by making it more/less inductive). But again, haven't had the time to bend test the unit to see what its doing.
carkrazed
« Reply #12 on: July 10, 2013, 03:47:00 PM »
I wanna drop the hammer on that Chinese VFD but i'm not sure how if it has an input I can use for my low pressure switch.
mandrel-bends
« Reply #13 on: July 12, 2013, 01:11:08 AM »
Your pressure switch should be just contact closure. The VFD should have i/o you can switch for either "run" or "enable" or both by putting the proper voltage across that switch and into your vfd. I would email them for a manual.
« Reply #14 on: July 12, 2013, 06:12:50 PM »
