Author Topic: Who's got a GSR basemap...or chip I can rip one from?  (Read 11268 times)
« on: May 07, 2009, 05:31:43 PM »
Trying to get all my shit together for the impending swap.
Can't find one on Xenocron's bin repository, and don't know how to find the damn things on pgmfi.
kthxbai
Re: Who's got a GSR basemap...or chip I can rip one from?
« Reply #1 on: May 07, 2009, 05:39:57 PM »
setup?
« Reply #2 on: May 07, 2009, 05:49:42 PM »
DURRRR I guess that is important (where's the dunce smiley)
LS block
B16 head
GSR cams
B18C crank
B18C rods, pistons
Thick cometic headgasket
Compression will be around 9.25:1 according to the calculator
Injectors I'm not sure of, but I know how to adjust the multiplier.  Will probably start with the stock 240cc.
Dweezil
    • Michigan Civics
« Reply #3 on: May 07, 2009, 06:41:33 PM »
I'd start by importing the P72 maps into the P30 code and going from there.
BoostForLife
« Reply #4 on: May 07, 2009, 06:51:10 PM »
Here's my friends bin.
LS B18A1 block
P61 Head
A little lean in WOT non-vtec, perfect 13:1 in vtec, idle is 14.7
P30 Base, should be good enough to get you going, but you know that no 2 motors run the same.
