Author Topic: CR D14 W/ Z6 head  (Read 14091 times)
walter
CR D14 W/ Z6 head
« on: August 04, 2013, 05:33:53 PM »
Hi, do you know what CR will get a D14z2 with Z6 head? i can't find more info for calculate it.. i think D14Z2 is same as D14A3/4...
Re: CR D14 W/ Z6 head
« Reply #1 on: August 04, 2013, 08:58:14 PM »
If the d14 head is the same as the non-vtec head, it should bump it up 0.7 points. We don't have ANY d14's in teh USA, so I have no idea about the heads. I'm presuming 138mm rods, 79mm stroke, and 207mm deck height.
« Reply #2 on: August 04, 2013, 11:25:06 PM »
Can you cc the d14 head?
walter
« Reply #3 on: August 05, 2013, 05:20:21 AM »
yes, D14 is "Econo head" non vtec. it works with 8 valves until econo get off then i runs with 16v. a rare vtec system lool.
i can't cc D14 head in this moment :(
« Reply #4 on: August 05, 2013, 08:48:18 AM »
Actually it would drop by 0.3-0.4 points: the 96+ vtec-e heads use the same head as the d16y8 vtec head. That's now assuming it started at 9.4:1 like the d16y5.
