Author Topic: Dizzy problem?  (Read 9247 times)
walter
Dizzy problem?
« on: September 04, 2013, 05:43:42 PM »
Hi there! im having problems with a Z6 Turbo, first start is perfect but once it's warmed up engine doesnt start good, sometimes start and somtimes not, checked and there isnt spark or sometimes spark is ...soft?  not get enought spark for start engine..first time i thought was rotor or cap but after to check it better i assume problem could be with coil? or what the hell could be this problem? i'd like to be sure for replace it since i dont want a  used/junk dizzy..
Re: Dizzy problem?
« Reply #1 on: September 04, 2013, 05:58:32 PM »
Check out the ignitor or possibly the coil, ignitor is most likely the issue.  :noel:
Re: Dizzy problem?
« Reply #2 on: September 04, 2013, 06:17:28 PM »
this
Re: Dizzy problem?
« Reply #3 on: September 04, 2013, 06:56:52 PM »
Found this to help with troubleshooting the ignition.
http://techauto.awardspace.com/ignition.html
walter
Re: Dizzy problem?
« Reply #4 on: September 04, 2013, 07:01:37 PM »
ill check it tomorrow. thanks!!!!!
