Author Topic: 1671 HP!  (Read 9419 times)
1671 HP!
« on: September 10, 2013, 03:34:01 PM »
On a 42' boat.
 ;DDD
Thought some might be interested.
Hydra-Sports 42 with triple Seven Marine 557's Teaser video
Re: 1671 HP!
« Reply #1 on: September 10, 2013, 04:03:29 PM »
That's all?
Re: 1671 HP!
« Reply #2 on: September 10, 2013, 04:14:31 PM »
The most it's been built with so far is 1400.
We think this 34k+ lb bitch will hit high 70's when we water test it.
I'm goign to try to film that also.
Re: 1671 HP!
« Reply #3 on: September 10, 2013, 04:52:58 PM »
Are those GM LS engines with a lower unit and gearbox bolted to them?
Re: 1671 HP!
« Reply #4 on: September 10, 2013, 06:13:04 PM »
I read 167 hp and assumed the thread was about your s10
Re: 1671 HP!
« Reply #5 on: September 10, 2013, 07:58:24 PM »
LSA engines. Caddy CTS-V, Camaro ZL1.
http://www.seven-marine.com/
lol
« Last Edit: September 10, 2013, 08:04:13 PM by Ntrain2k »
Re: 1671 HP!
« Reply #6 on: September 10, 2013, 08:35:16 PM »
I am guessing those are 8.1 based?
Re: 1671 HP!
« Reply #7 on: September 11, 2013, 07:07:58 AM »
LSA
The supercharged 6.2L LSA is similar to the LS9 and debuted in the 2009 CTS-V. The LSA has been SAE certified at 556 bhp (415 kW) at 6100 rpm and 551 lb·ft (747 N·m) at 3800 rpm. GM labels it "the most powerful ever offered in Cadillac’s nearly 106-year history". The LSA features a smaller 1.9L capacity supercharger rather than the 2.3 L variant of the LS9. Other differences include a slightly lower 9.0:1 compression ratio, single unit heat exchanger and cast pistons.
A 580 bhp (430 kW) and 556 lb·ft (754 N·m) version of the LSA engine is used in the 2012 Camaro ZL1. On 15 May 2013, Holden Special Vehicles announced that this version of the LSA engine will also be used in the GEN-F GTS.
Applications:
2009–2013 Cadillac CTS-V
2012–present Chevrolet Camaro ZL1
2013 Holden Special Vehicles GTS (GEN-F)
Re: 1671 HP!
« Reply #8 on: September 11, 2013, 10:54:02 AM »
If it doesn't jump out of the water when you punch it, it's a waste of money.
Re: 1671 HP!
« Reply #9 on: September 11, 2013, 08:09:15 PM »
It gets up and moves pretty good for a fat girl.
