Author Topic: NGK AFX. Cutting down that mile long cord?  (Read 17512 times)
pitobread
  • I'm a llama.
« on: September 16, 2013, 06:28:15 PM »
Good day sirs.  Was told via NGK support and also in the manual in not so many words that cutting down the mile long cabling on my AFX is a not recommended for calibration reasons.   I have a Miata and having that bundled up cabling under the limited dash space is dumb.  I don't think it would be an issue but I figured you fellas would have some insight and input.
Re: NGK AFX. Cutting down that mile long cord?
« Reply #1 on: September 19, 2013, 09:54:47 AM »
I approve!
« Reply #2 on: September 19, 2013, 10:37:23 AM »
Hold me.
pitobread
  • I'm a llama.
« Reply #3 on: September 19, 2013, 06:31:24 PM »
lol. It seems like such a minute change in resistance especially considering the sensor is calibrated and the unit can run on 11-28v.. It must be able to compensate for such a small change.
Should I worry?
clwtwizted
  • Fuck You!!!
« Reply #4 on: September 22, 2013, 11:22:29 PM »
 I think the problem in the cable may be in the shielding. If you splice all the wires and leave it open wiring it may get a mixed signal so as long as once you get done splicing it to tape it back together shouldn't hurt it.
« Reply #5 on: September 23, 2013, 04:47:56 PM »
The sensor is probably calibrated for a certain wire capacitance.  Changing wire length alters capacitance which effects the absolute value of your sensor offset slash calibration. Its not a big deal if you use your wideband as a delta measurememt and not think of it as an actual absolute number. (It probably wont 3v3n change the absolute number very much)
« Reply #6 on: November 02, 2013, 01:42:40 AM »
I'd never run an o2 to get absolute value, just to make sure the map is even and use the plugs to give the final word.
I can tell you I've lengthened the cable on my LC-1 w/o ill effects. I took an old PLX cable & put the correct end on it so the unit wasn't dangling in the engine bay.
