Author Topic: Wastegate placement advice needed on sinktrap manifold  (Read 42889 times)
ohisofly
« on: January 05, 2014, 03:59:13 PM »
As some of you know I'm in the process of making this manifold, I'm just unsure where to put the wastegate. Here's what I'm working with
This would be the ideal place for my wastegate, but as you can see the flange wouldn't be fully exposed to collector part of the manifold
Would this still be ok?
91 Crx Si - turbo ls vtec
Re: Wastegate placement advice needed on sinktrap manifold
« Reply #1 on: January 05, 2014, 04:30:28 PM »
you'll bee ok with it right there
ohisofly
« Reply #2 on: January 06, 2014, 01:30:15 PM »
Sweet sounds good
The_Beave
  • The Red Tape Avenger
    • Beaver Built Blog
« Reply #3 on: March 11, 2014, 08:59:54 AM »
I'd put a dual inlet for the wastegate on the 90* turns up. This will give the wastegate flow priority yielding better control.
Not so obvious and ruthlessly odd.
Fab blog: http://beaverbuilt.blogspot.com
ohisofly
« Reply #4 on: May 16, 2014, 12:19:36 AM »
I appreciate the input but unfortunately that's just not an option, I literally don't have the room
I'm finally working on this again and need some more input, here's how I cut it
Here are my filler pieces
Does it really make a difference which way this pipe goes (both pics below) or can I just get away with it being at a straight 90 degree? Just wondering because it would make things much easier considering that first piece is the only curved piece that's that size, at least out of what I have found so far
« Reply #5 on: May 16, 2014, 12:45:07 AM »
Your gonna have a bunch of problems with keeping boost steady with that setup right there. Your only bleeding off exhaust from 2 of your cyl.
« Reply #6 on: May 16, 2014, 08:50:49 AM »
looks like he cut the fuck out of the insides of both tubes.
maybe going to box it in?
I think its wonderful
« Reply #7 on: May 16, 2014, 11:50:46 AM »
Didn't even see that. So I guess if that's the case, if possable run the one with the curve so it's a little smoother transition to your wg. Otherwise this shit nig nog black and I approve of this :-)
ohisofly
« Reply #8 on: May 16, 2014, 04:11:24 PM »
Yep going to box it all tonight, I'll post pictures when I get a chance
« Reply #9 on: May 20, 2014, 09:36:47 AM »
For the best control, it would be placed at the bottom side of your header connection flange.
« Reply #10 on: May 29, 2014, 01:40:25 PM »
I'd have put it at the top of the 2 tubes just before the final 90* elbows coming up. The slight backpressure caused by the elbow will force more than enough gasses into the WG tubes. I'd make the tube into a mini collector similar to the turbo collector. You could have then divided both and used a divided HX35 for 10 shades of awesome.
Gold DA9
  • OG LURKER
« Reply #11 on: May 29, 2014, 05:49:30 PM »
run dual wastegates.
ohisofly
« Reply #12 on: July 21, 2014, 07:20:46 PM »
This thing is finally done, the manifold was boxed (unfortunately not with stainless) and then went over again with the tig to smooth the welds out. It's incredibly sturdy so as of now I don't plan on any extra reinforcing to support the manifold.
« Reply #13 on: July 27, 2014, 02:03:19 PM »
Greasy as hell.  Nice.
« Reply #14 on: July 27, 2014, 08:19:22 PM »
The last sinktrap I made was exactly the same as your design, except it was WAY further away from the manifold. Like, we had 2-3 feet of pipe off the manifold until it hit the WG. It was fine, I wouldn't worry about it.
ohisofly
« Reply #15 on: July 30, 2014, 06:59:55 AM »
Sounds like I'll be fine then, good to hear  O0
