Author Topic: Small turbo for 250hp vitara setup?  (Read 21497 times)
walter
« on: January 21, 2014, 09:32:44 PM »
Hi! im looking for a small turbo for a Vitara/eagle D16 setup, it will runs time attack so fast spool will be required..looking for around 240-250..any help? Thanks! :)
Re: Small turbo for 250hp vitara setup?
« Reply #1 on: January 21, 2014, 10:01:55 PM »
DSM turbo, td05h 14b or something
« Reply #2 on: January 21, 2014, 11:00:55 PM »
16g
« Reply #4 on: January 23, 2014, 12:05:26 PM »
Shit not for that price............
Minor Threat
« Reply #5 on: January 23, 2014, 04:33:54 PM »
What's your budget Walter?
I would try and run a T28 if you can find one, or a T25 is second choice.
walter
« Reply #6 on: January 23, 2014, 09:53:11 PM »
Hi, im running with a SR20DET T28 journal bearing already, i have to say it needs a lot for tune it but looks like it have lag for vitara setup... i was thinking about T25 but not sure if there are other turbos cheaper even..
« Reply #7 on: January 23, 2014, 10:42:06 PM »
if that turbo lags, you have an exhaust leak. lol
« Reply #8 on: January 23, 2014, 10:50:45 PM »
This or turbo has gone to shit, or you have the ignition timing off or something  :noel:
Minor Threat
« Reply #9 on: January 24, 2014, 12:00:01 AM »
If that T28 is laggy you're in trouble...there's probably something not right with the setup.
Only thing smaller and cheap is a k03 or k04 from an 1.8T VW/Audi but you'll be maxing it out to get it up past 200whp.
walter
« Reply #10 on: January 24, 2014, 09:29:06 PM »
im using GT28 3inch compressor housing, it should helps i think but as i said it needs a lot of tuning, i will try with it then. thanks! :)
my setup..
walter
« Reply #11 on: January 25, 2014, 07:40:03 AM »
btw, what rpm it's supposed to get full boost (14-16psi) on a D16 vitara build with T28?
« Reply #12 on: January 25, 2014, 10:48:33 AM »
take a look at my crx post. I was running a 14b on forged Y8. made 247whp at like 17psi.
flat_black
« Reply #13 on: January 26, 2014, 01:04:22 AM »
Im using a Ford T3 turbo, it made 210whp Mustang dyno on a low compression B20A non intercooled with a meth kit on 12psi
« Reply #14 on: January 26, 2014, 04:16:49 AM »
Probably in the low 3000's. When I ran a 50trim T3 (smaller cold side, larger hotside), it made 10psi before 3500rpm. That was with a stock Civic B-pipe and stock axle-back.
walter
« Reply #15 on: January 26, 2014, 06:54:55 PM »
thanks for info!! i got 7psi around 3.500rpm with light tune..i think i will keep that turbo then.  :noel:
