Author Topic: Cheap -an stuff  (Read 6870 times)
Cheap -an stuff
« on: April 13, 2014, 06:10:14 PM »
I found this today while doing some searching for things. pretty cheap prices, but they are a little limited on what all they have.
http://www.anprofittings.com/
Re: Cheap -an stuff
« Reply #2 on: April 13, 2014, 09:03:07 PM »
The only problem with the off brand China stuff is that some of it isn't cross compatible with the real deal stuff.  :?:
Re: Cheap -an stuff
« Reply #3 on: April 13, 2014, 09:27:41 PM »
I have used china fittings with real stuff. All of the hoses I get come off airplanes, and they work with china stuff.
94EGCoopey
  • Eternal noob
Re: Cheap -an stuff
« Reply #4 on: April 13, 2014, 09:35:09 PM »
I buy all mine off ebay from a guy named ABadCamaro**** Based out of AL iirc. Great prices and everything has always interchanged for me.
DraginX
Re: Cheap -an stuff
« Reply #5 on: April 13, 2014, 09:35:37 PM »
I've used them together also and never had an issue. Some are a bit harder to get on that others but I've yet to have issues. Not saying some won't have issues.
Re: Cheap -an stuff
« Reply #6 on: April 13, 2014, 10:28:13 PM »
I've had good luck with the seller on ebay getfast1. Has lots of odd ball stuff.
Re: Cheap -an stuff
« Reply #7 on: April 18, 2014, 12:18:53 AM »
I've seen a tool (Allstar "Koul Tool") that you put your fitting into (2-sided case), then shove your frayed hose into the hole (funnel shaped) and it makes it easy as hell. It should let nearly any slightly off hose/fitting intermix with a bit of lube. When it's tight, just use lube & feed it inch by inch... ::)
n/a mike
  • Mr. Hotpocket
Re: Cheap -an stuff
« Reply #8 on: April 18, 2014, 12:39:08 AM »
all 3 inches right?
