Author Topic: Which Turbo to Use?  (Read 15883 times)
TWOLOUDnPROUD
Which Turbo to Use?
« on: May 09, 2009, 05:30:10 PM »
I have two turbo's one is a T04B H-3 and the other is TO4B V-Trim so which one should i use? Here the maps for both turbo's tell me what you think.
T04B H-3
T04B V-Trim
Re: Which Turbo to Use?
« Reply #1 on: May 09, 2009, 06:11:50 PM »
I say they are so close, it will make very little difference.
reddevil
« Reply #2 on: May 09, 2009, 10:46:58 PM »
Pictures please,
TWOLOUDnPROUD
« Reply #3 on: May 09, 2009, 11:00:03 PM »
Pictures please,
They look the same the only difference is the T04B H-3 has a bigger compressor wheel Inducer2.298  Exducer2.750 and the T04B V-Trim is Inducer2.160  Exducer2.750
BoostForLife
« Reply #4 on: May 09, 2009, 11:19:07 PM »
I would use the H-3 if you're not going to push any more boost than 15psi. .138 of an inch isn't much difference, but at 15psi it should show some gain.
TWOLOUDnPROUD
« Reply #5 on: May 10, 2009, 03:41:17 AM »
I think i am going to use the V-Trim im doing a two stage boost control 8 psi low and 15 psi for high boost and the V-Trim maps looks good for that. The V-Trim flow rate is 48 lbs/min and the H-3 is 49 lbs/min not that much of a difference so i will use the V-Trim for now and try the H-3 later down the road.
« Last Edit: May 10, 2009, 03:43:11 AM by TWOLOUDnPROUD »
hotrex
« Reply #6 on: May 10, 2009, 06:04:04 PM »
i used a t04b s trim on my build d series and it made 259 at 15 psi  back in the day.
the v trim is the one id use
« Reply #7 on: May 10, 2009, 06:34:51 PM »
Uh, it's not .138 of an inch difference.  It's .48 in2 difference, basically 12% bigger.
« Reply #8 on: May 12, 2009, 11:29:00 AM »
For power, H-trim. Otherwise the V-trim will get very close, but have a larger powerband. H-trims are less common for a reason.
FYI you guys also have to factor in speed - radians/sec is the same, but inches/sec is higher on the H-trim, given the same shaft speed.
