Author Topic: Crome lambda reading doesnt works..  (Read 35829 times)
walter
« on: August 19, 2014, 07:28:04 PM »
anyone using crome have lambda reading working properly? mine never worked using crome gold map, of course wideband is wired to ecu and reading afr and voltage...
Re: Crome lambda reading doesnt works..
« Reply #1 on: August 19, 2014, 11:15:50 PM »
Lambda always worked for me, but I have not used gold much.  :noel:
« Reply #2 on: August 20, 2014, 01:30:26 AM »
you talking about the screen where it fills in all the blank cells? i had a HUGE issue with that. then when we had my car on the dyno the man himself LEED noticed something he didnt like, and fix it. my baud/sampling rate was way low, so it would never really work. works camp now.
walter
« Reply #3 on: August 21, 2014, 09:16:05 AM »
tubohf, yes, screen when you datalog and show afr you get in that cell...
« Reply #4 on: August 21, 2014, 12:20:17 PM »
yeah. Dave said the baud rate on my computer and/or that com was set too low. so the sampling rate was all fucked. and wouldn't fill in the cells. so I was just getting vacuum cells and nothing into boost since the pulls where so short... now it works pretty champ. it fills in lots of vacuum and all the way threw boost. its got me hating crome a lot less these days....
I can dig out my laptop and check the settings for ya later.
walter
« Reply #5 on: August 21, 2014, 12:37:13 PM »
what you means with baud rate? you means settings in tuner comm? screen i means is F11 "show lambra readings"..i can see how datalogging works but doesnt put any value there.. that always keep blank..
« Reply #6 on: August 21, 2014, 12:54:06 PM »
tuner com settings and they need to match the com settings in device manager.
walter
« Reply #7 on: August 21, 2014, 01:29:09 PM »
does it possible if both are different ostrich/hulog dont work properly? i means, mine works good so it should match both baud rate then? i will check it today anyway!  :)
walter
« Reply #8 on: August 23, 2014, 09:07:37 PM »
setting match and still doesnt work. :-\
