Author Topic: Crome Gold System events doenst works..  (Read 27651 times)
walter
« on: August 29, 2014, 07:24:11 AM »
http://forum.pgmfi.org/viewtopic.php?f=55&t=16735#p106031
trying to get this done but doenst works to me.. using Gold Map 0.94...
walter
Re: Crome Gold System events doenst works..
« Reply #1 on: September 09, 2014, 07:44:09 PM »
got good reply, what i dont know is how to wire it for get it working  :-\
Sedrostyle
  • Turbine Noob
« Reply #2 on: September 12, 2014, 10:43:16 AM »
Are you talking about fan control? Dunno if I'm seeing the same thing.
I haven't even looked into seeing if the system events worked. I didn't see any downloadable folders. Fan control should be in the ecu itself yes?
walter
« Reply #3 on: September 12, 2014, 05:25:18 PM »
only in OBD1, OBD0 doesnt..i need to wire fan control as OBD1 one and i dont know how to begin!
Sedrostyle
  • Turbine Noob
« Reply #4 on: September 12, 2014, 10:18:20 PM »
You are running obd1 yes?
Just follow the pin# on event 1 of your choice. Run it to the fan and ground the other side?
walter
« Reply #5 on: September 13, 2014, 06:24:44 PM »
that's why i was thinking to do but i dont know if ecu output is positive or it just output ground signal, algo i dont know what means that invert output..i have to test it and measure that pin.. i think could use IAB pin wired to fan switch..
« Reply #6 on: September 14, 2014, 12:01:11 AM »
Obd1 fan control grounds a lead to run a relay.
Can't use it to run a fan directly
walter
« Reply #7 on: September 14, 2014, 07:04:11 AM »
i meant to switch fan , looks like ecu grounds outputs only and for switch looks it needs +12v..
