Author Topic: microsquirt ?'s  (Read 29065 times)
jeremy_nash
microsquirt ?'s
« on: October 02, 2014, 09:17:27 PM »
At the dyno day the grand wizard mentioned going doing itb's off a cbr on my 3cyl geo.
First question is, will it be possible to separate one of them from the set of 4? It appears I may be able to attack it with a cut off wheel
Second question is with engine management, I was looking to use microsquirt for simplicity.  My crank has a 6 tooth wheel, can it be used to trigger the microsquirt?
jeremy_nash
Re: microsquirt ?'s
« Reply #1 on: October 02, 2014, 11:09:51 PM »
this is a pic of what my gear looks like its from a 96
this is another option, one from a 99+
stealthiskey
Re: microsquirt ?'s
« Reply #2 on: October 03, 2014, 08:14:56 AM »
don't know much about microsquirt, but I've been doing some megasquirt applications lately.
If it's anything like megasquirt you could probably use either wheel, but I think the 6 teeth would be much simpler to set up.
jeremy_nash
Re: microsquirt ?'s
« Reply #3 on: October 04, 2014, 01:19:17 AM »
So ive been doing a little more research.  It appears I can remove one of the teeth off my 6 tooth wheel, and run it as a 6-1 wheel.  Apparently it will need to be batch fire, which I am fine with.
