Author Topic: new car  (Read 17276 times)
new car
« on: May 27, 2015, 02:04:12 AM »
ug what did i get myself into $$$$$$$$  O0 O0 O0
Re: new car
« Reply #1 on: May 27, 2015, 07:05:21 AM »
Into a car that once held the record of the heaviest doors at 110# each.
This looks to have a lot of potential.  :noel:
« Last Edit: May 27, 2015, 11:31:58 PM by 92CXyD »
Re: new car
« Reply #2 on: May 27, 2015, 10:21:16 AM »
I like it. There is one on the good guys protouring circuit and it looks and handles bad ass.
Re: new car
« Reply #3 on: May 27, 2015, 10:43:44 AM »
For some reason these are one of the only body styles camaros that I like
good buy
Re: new car
« Reply #4 on: May 27, 2015, 12:39:53 PM »
I like a split bumper, but that one is close enough.
Re: new car
« Reply #5 on: May 27, 2015, 01:41:52 PM »
yea its gunna be a money pit for sure. but it'll be a badass car when its finished.
already ordered door hinge rebuild kits lol. they sag like a bitch
Re: new car
« Reply #6 on: May 27, 2015, 01:45:28 PM »
gunna do a lq motor and a 6 speed.
get the body work done and painted, new interior
probably going to be a slow process
Re: new car
« Reply #7 on: May 27, 2015, 01:46:12 PM »
not sure where to start, what makes the most sense.
motor and tranny conversion first?
interior??? (cheaper??)
body & paint (expensive!)
Re: new car
« Reply #8 on: May 27, 2015, 01:53:57 PM »
I would do motor and trans, then interior, then body work. That way I'd you fuck up the paint while installing motor it's no big deal. Then the interior and so you can enjoy sitting in it while driving it. Then paint. Your gonna get looks no matter what you do. It's a old muscle car.
Re: new car
« Reply #9 on: May 27, 2015, 02:23:29 PM »
ya its a 70. 350 LT. so it was originally a 350 car but not a SS or z28
id probably go the route you are thinking, i thought of the same reasons, doing a motor swap and conversion with nice paint and stuff, just seems like i'd do something to fuck it up
Re: new car
« Reply #10 on: May 27, 2015, 02:26:47 PM »
the engine in it now is a 383. don't know much about it has some cam and dunno about the heads they are cast iron though.
it runs ok has decent power for a old engine but not a powerhouse by any means
Re: new car
« Reply #11 on: May 27, 2015, 02:31:17 PM »
if i don't go the mexican route, the body work and paint will be 8-10k  :-X
not sure how much i'll need to spend on a LQ + t56 swap. i'm guessing 3-4k
interior i'm not sure but a couple thousand i'm betting.
it a lot of moeny to dump into the car i see them restored on craigslist for 15-25k
Re: new car
« Reply #12 on: May 27, 2015, 05:41:44 PM »
Idk man. You can get a junkyard lq4 for around 500-1000. Depending on how complete/use able it is. Throw a big cam in it, some valve springs, some gaskets, and maybe bearings and rings and a srt of headers and just turn the key and enjoy it. Or just springs and throw some boost on it!! The t56 is the expensive part. Most I see on craigslist are in the 1700 range with the bellhousing. But for another 1300 you can get one that's new and beefed up a little.
Re: new car
« Reply #13 on: May 27, 2015, 05:49:25 PM »
i wanted to a the 6.0 lq motor, i think its lq9 but i would get a lq4 if it was cheap
oh you're right the lq4 is 6.0 the lq9 is too.
yea that the one i want. the tranny will be expensive :(
Re: new car
« Reply #14 on: May 27, 2015, 10:34:15 PM »
Only real difference between the lq4 and the lq9 is compression. Lq9 has flat top pistons and the lq4 is dished pistons. Both will make greater power and gobs of tq with minamum work.
Re: new car
« Reply #15 on: May 30, 2015, 03:29:52 PM »
Running 5.3 with wire harness and everything except the ecu..... $900 and it's down by you. http://seattle.craigslist.org/see/pts/5048990839.html
Re: new car
« Reply #16 on: May 30, 2015, 06:12:55 PM »
Cool
Re: new car
« Reply #17 on: June 01, 2015, 02:02:44 PM »
i really wanted a 6.0 but they are pretty spendy and harder to find. might just do a turbo 5.3
Re: new car
« Reply #18 on: June 01, 2015, 02:11:27 PM »
Try to get a gen4 if you can. Stronger rods and floating pistons pins.
Re: new car
« Reply #19 on: June 02, 2015, 12:06:29 AM »
5.3 + boost will get it done.
those cars are so ugly, but definitely cool at the same time...  :noel:
car-part.com <~lots of yards in eastern washington with engines for good prices.
Re: new car
« Reply #20 on: June 04, 2015, 05:29:59 PM »
Not as ugly as Novas. :P
F-body > *
Re: new car
« Reply #21 on: June 05, 2015, 12:08:10 PM »
gunna buy the motor and trans soon.
i'll buy a 6.0 if there is one, if not i'll just get a 5.3
Re: new car
« Reply #22 on: June 05, 2015, 12:14:03 PM »
Try to find a 4th gen. Might be a couple hundred more then a Gen3 but the rods are way stronger.
Re: new car
« Reply #23 on: June 05, 2015, 01:39:52 PM »
which year switched? 2001 and newer?
Re: new car
« Reply #24 on: June 05, 2015, 01:48:30 PM »
2004
Re: new car
« Reply #25 on: July 23, 2015, 03:21:26 PM »
some shitty shit happened over the last couple days lol
first off, i found a guy on craigslist selling two 5.3s with 100k miles for $800... $400 a piece. i was all over that shit immediately. he had to work, then he had to do this and that and finally he said "my brother sold them when i was at work". sounds legit. im sure he must've figured out how much they were worth. :(
then the camaro was running shitty with this old mallory dist and coil so my buddy (he is a total nigger rigger) was like yea i have some HEIs you can use one for a while it came out of a running car...  so i get it, has all the wires attached... so i'm like yea its probably fine. i put it in the car it idles great and cruises ok runs like shit wot but whatever. mess with it later
i drive it a couple days here and there and last night i go to portland, coming home about 10pm it dies right in the middle of columbia blvd. some ppl push it off the road onto a side street. no spark...
pull the cap off, pull the rotor... mechanical advance is fucked up. only one side has a spring on it, both sides have no bushing, the weights are flopping around inside... really this came off a running car? but that wasn't why it wasn't running. module or coil went to shit. probably module.
call my wife, she drives out with module off the bench... jb and i are playing soccer in some random street at 1am on columbia blvd lol. guess why the module was sitting on the bench with random shit? because its fucked up too. drive back home, put together a dist out of random parts. drive back, drop it in. runs like a sum bitch. actually feels like a 383 now.
got in bed at 5am.
fml first world problems
