Author Topic: There is low budget and then there is this V1.1.2  (Read 16775 times)
evo_lucian
« on: March 25, 2016, 08:19:43 PM »
i just wanted to share my build with you guys since it fits right in here. Picked up this 1997 Honda Ferio last year and decided to fix it up.
After paint
Didnt really have the $ to do a chipped ecu + ostrich or Neptune so I did the next best thing. DIY Standalone ECU.
Speeduino V.04 2 channel PCB with Sainsmart Arduino Mega
Gutted Distributor. As you see, I only left 1 VR sensor. Speeduino can work with the stock dizzy but i chose to mod it to do wasted spark/COP
Modified 24 tooth trigger wheel with 2 teeth shaved off 180 degrees apart
Back together, minus the Cap
« Last Edit: March 26, 2016, 08:41:16 AM by evo_lucian »
evo_lucian
Re: More time than money build
« Reply #1 on: March 25, 2016, 08:29:12 PM »
Started a Homemade turbo System.
I decided my Speeduino A Plug and Play unit,  I used an old toyota 4Agze obd1 ecu case and went to town on it. I now have have 2 IS9V5056S3S Ignition drivers mounted in the ECU as well.
how the bay looks now
Cleaned up a bit. I tie strapped the Speeduino a bit further up under the dash to clean things up and to try and safe guard it from someone stepping on it.
I never mounted my IAT sensor on my intake piping, I pretty much just had it dangling in the engine bay. I figured there is a huge difference between the air coming in from my cold air intake and what the sensor was reading in the bay so i decided I would just take off the cold air intake since I didn't wanna go through the trouble of lengthening the IAT sensor wires since I will be going turbo soon. I just placed it on the air filter. It will do for now.
Cleaned up the wiring a bit more. I used one of these break out boards and mounted the speeduino in the glove compartment. No I dont have to worry  about someone stepping  on the ecu on the floor
« Last Edit: March 25, 2016, 08:38:23 PM by evo_lucian »
« Reply #2 on: March 26, 2016, 02:51:24 AM »
Bad ass, saw this on DSO, was wondering why you didn't share it here?   :noel:
evo_lucian
« Reply #3 on: March 26, 2016, 07:59:20 AM »
Started the thread on DSO because I was bored but basically never started one here because I was lazy  :'(
