Author Topic: BDVT and King Kenny Spikers 401K project :Vera, 63NovaSS powered by PorkCHOP  (Read 48784 times)
Me and my old man sold the Accord and decided to build a car.
A RWD v8 turbo car
We bought a really pretty tubbed caged prostreet 63SS nova and gutted it... cut the front end off and tore it all apart, sold the 406 roller SBC with TH400 motor/trans - rebuilt the back half of it, added ARB some wheelie bars and other shit to the chassis, Mencer AFCO suspension, refresshed all of the hardware used in the back half powdercoated everything and  the motor and trans are ready so far built and ready to go... Moving onto the front end now building a core support for the big ass Afco radiator and turbo support  Hotside and figure out the intercooler piping into the rear of the car for the big ass A2W... and trying to have it done by end of June. It will run June/July latest
Ill post a proper build thread when I have time
Ross built the motor (showing me the ropes of the LSX shit) and is helping us with this car hugely (of course...)
376 CU in LSX
LSX 6 bolt block
TFS 245 Heads with the business
Callies Dragonslayer
Callies UltraBillet Rods
LJMS Fuck your mama cam
Wisecos
625 Mainstuds
ARP headstuds.. alot of them
Belt driven fuel pump
ful length 2x3 Full frame rails and back half
Subframe connectors
14 pt cage
Motor plate
Lateral locators
Pro Ladderbars
Menscer double adjustable shocks.
RPG ARB setup
Strange Pro-nodular center with spool and 35 spline pro Hytuf axles 5/8 studs
31x18.5x15 rear tire
Mustang 2 front end and rack and pinion steering (Will go strut next year)
Wheelie bar setup yet to be figured out
JW ultraglide Turbo shaft vasco and 300m shafts 10 clutch high drum 1.8 straightcut 1st with brake
Strange 9" with Ultra spool 35 spline pro axles and Willwoods
FTI mechanical diode 10 inch Promod converter
Forced inductions Billet S488 with v2 Race cover and 100mm T6 1.32 hotside
MS3 PRO on the 1s and 2s
Traction control
ALOT of meth
2000 HP A2W in the back half
Afco radiator
Mezzeire electric pump
Davies icebox IC pump
Safety first
Meet Porkchop.
White powerglide
Whirleynig
And Vera
Ill update it with more later. Ross heckled me into posting something.
Fuck you
HHH
You looked faggot
« Last Edit: April 06, 2017, 08:14:59 PM by bigdaddyvtec »
It moved.
This place is dead as fuck, trying to breath life in its like trying to get rid of the HErp form Hotrex. Seemingly futile. Sad.
Build is flat out sexy as fuck!!
pics from this weekend
« Last Edit: April 09, 2017, 02:14:01 PM by bigdaddyvtec »
SOHCKLR657
FASBELAD, beautiful buddy :o
LOL aint nothing stock about 1 part on this motor but the windage tray ;)  Literally.
Eggylshatch
  • Pen15 Club President
Looks tits. How many horsepowerz are you shooting for?
Can't tell for sure, but is the turbo mounted to the body rather than engine? Isn't that going to make crackage?
Damn thats one BIG ass baby eater turbo. Big tires, big ass turbo+ nova= FUCK YES!!! :noel:
Motor plate and solid mounts. it aint goin nowhere... ;0 double slip fit between PS and DS hotside.
Should make around 1400-1500 wheel.
It will be a hot minute before its turned up ll the way... well be taking our time dialing it in along the way
Don't want to put to much power down b4 you get everything dialed in. Smart way to do it. That's what I would do.
SHe got a skinny little ass but it tiiiiiiight
Got the underside of the car painted and everything powdercoated....
Rear end ladderbars ARB and SHocks went in last night.
RPG Pro antirollbar
Big bearing Ford housing with new housing ends bearings and bracing on housing
Strange Pro Nodular center section
Moly caps
3.70 US gear ring and pinion
Strange pro spool
Strange CHroMo yoke with magnetic collar for traction control sensor
Billet u bolts
Strange Pro 35 spline axles
5/8 studs
Woillwood brakes Menscer AFCO double adjustable shocks
Bang away on hotside tonight and tomorrow
« Last Edit: April 21, 2017, 07:29:10 PM by bigdaddyvtec »
Awww yea, wood happening..
suck my nuts
Ross came over and we got busy as fuck.
Driveshaft test fit
I'm excited to see this bitch on the track making some test hits getting everything dialed in.
DSharp
GAWD DAMN SUHN!  All those pie cuts are raising my blood pressure, must have taken forever to weld that.  Shit looks good though.
Big money old man shit right there
Eggylshatch
EVERYTHING IS SO MINTY CLEAN
more stuff happenng but lazy to post
Fuck that looks amazing :o :o :o
A million and a half times cleaner than my build
So much fucking chub happening in my undies
Random Hero
Veddy nice, missed this thread being posted. Can't wait to finish this pig up and get er down the strip.
will be updated. soon
Eggylshatch
Air to water unit in the cabin? and then piping will wrap back around the other side and turn into the intake manifold? My simple mind does not compute. Or is the turbo just to blast warm air on your nuts when you're driving? That'd be pretty cool too. We'll call it a nova blow job.
bump
