Author Topic: dim headlight  (Read 15559 times)
crx2fast
dim headlight
« on: May 11, 2009, 12:13:40 AM »
ok my passengers side headlight has been dim for like 2 years now..
i have replaced the headlight itself, bulbs, tried HID bulbs, switch on steering column and the ground itself off the headlight..  i'm out of ideas.
possible fuse under the hood? doubt it..    new wiring harness?  hope not..  relay? fuck if i know..
any ideas?
car: 91 crx si
Ravage70
Re: dim headlight
« Reply #1 on: May 11, 2009, 12:52:11 AM »
bad ground
check your tranny to body ground, replace it
Re: dim headlight
« Reply #2 on: May 11, 2009, 02:02:54 AM »
bad gang ground......
Tranny to body ground is only for the starter, not the headlights.
Re: dim headlight
« Reply #3 on: May 11, 2009, 02:58:13 PM »
+1, it's right behind the headlight bolted to the innder fender.
Warrick's not the brightest.  :P
Re: dim headlight
« Reply #4 on: May 11, 2009, 04:04:49 PM »
Ravage70
Re: dim headlight
« Reply #5 on: May 11, 2009, 07:29:15 PM »
It is not only for the starter. My lights were doing all sorts of shit last week cuz that thing was broken and barely touching.
Warrick wins! :P
Re: dim headlight
« Reply #6 on: May 12, 2009, 01:40:42 AM »
Warrick is missing a couple ground straps as well as the aforementioned brain cells.
