Author Topic: Cessna 170 upgrade  (Read 48933 times)
Cessna 170 upgrade
« on: September 30, 2021, 07:33:25 PM »
So, I bought this airplane a while ago.  Engine finally let go.  Original engine is a 145hp carbureted 300ci Continental C145. Check out the wear on the OUTSIDE of the main bearing.
« Last Edit: September 30, 2021, 07:37:35 PM by malichite »
Re: Cessna 170 upgrade
« Reply #1 on: September 30, 2021, 07:37:00 PM »
We decided after this, time to go big or go home.  With this being a certified airplane, you have to either use the original engine, swap it under an STC or Field Approvals.  field approvals are insanely hard so we went the STC route.  The biggest engine we could do legally is a fuel injected 360ci 210hp continental.  Fuck it, time to blow all the monies.  First thing first, upgrade the fuel system.  Need to add a header tank for the fuel return loop.
« Last Edit: September 30, 2021, 07:42:30 PM by malichite »
« Reply #2 on: September 30, 2021, 07:44:06 PM »
Old header tank is buried behind the panel.  Need to make new fuel lines to run up to the wing tanks.  Will reutilize the old vents for fuel return and add new vents outboard on the tanks.
MTZ
  • Webadmin
« Reply #3 on: September 30, 2021, 08:01:57 PM »
i really need to get a part 103 and start flying
its called toering
« Reply #4 on: September 30, 2021, 08:40:39 PM »
Probably a lot easier to fly part 107 hahaha.  Since I have my pilots license, the part 107 was a gimmi.  Not sure how entailed it is if you dont have a pilots license, but let me know if you have any questions.
« Reply #5 on: September 30, 2021, 10:11:57 PM »
No turbo? Wtf......
« Reply #6 on: October 01, 2021, 12:38:29 PM »
Unfortunately to turbo it, it requires a field approval or deviation from the STC.  The seattle FSDO (FAA Office) is not approving crap for field approvals :(.
« Reply #7 on: October 01, 2021, 02:44:51 PM »
New engine mount hung and new engine test fitting.
« Reply #8 on: October 01, 2021, 11:03:03 PM »
Looks like a giant VW motor....lol I still want to go for a ride
« Reply #9 on: October 03, 2021, 04:59:36 PM »
But way more reliable  :noel:
« Reply #10 on: October 03, 2021, 10:28:05 PM »
Oh God, I would hope so. Not like you can just pull onto the shoulder when you in the sky.
« Reply #11 on: October 07, 2021, 01:31:52 PM »
FACLAD
