Author Topic: I'm an idiot  (Read 25686 times)
n/a mike
  • Mr. Hotpocket
I'm an idiot
« on: April 14, 2022, 04:59:40 PM »
The title was to get you to open the thread...
Ok, so my front brakes have been making the squealing from the low pad indicator thing for a little while. Last weekend they started grinding randomly (not everytime I break) so I figured I should probably change the pads before the rotors got damaged.
I go get some cheapo VatoZone pads.
Grab my daughter so she can learn to do brake pads.
When I take the pads off there is a shit ton of life left in them.
At least 50% thickness left.
Any clue what else could have possibly made a brake grinding noise?
Wheel bearings are good, driverside lower ball joint needs replacing.
Everything else is fine.
MTZ
  • Webadmin
Re: I'm an idiot
« Reply #1 on: April 14, 2022, 05:23:27 PM »
My wife’s GLC 300 has this same problem everything is within operating standards and she’s a squealer, sort of makes Me want to jump in the Acura... Makes one seem like a poor Bastard chasing the last brake 😅😂😂
its called toering
Re: I'm an idiot
« Reply #2 on: April 15, 2022, 09:12:33 AM »
Have similar issue with my 1g Integra, it was/is a caliper not moving freely on slides. (is b/c I diagnosed the issue, but not fixing until damn outside temps get above 60deg for longer than a minute)  :noel:
n/a mike
  • Mr. Hotpocket
Re: I'm an idiot
« Reply #3 on: April 15, 2022, 12:04:13 PM »
It took me 4 weeks to pull the pads off because it's either been raining or 100° here.
Finally got a good 70° day and the fucking old pads looked almost new.
So you think maybe the caliper not sliding properly?
It hasn't done it since I pulled out the old pads and reinstalled the old pads.  Maybe the caliper was hung up.
« Last Edit: April 15, 2022, 12:06:13 PM by n/a mike »
