Author Topic: How to remove tail light cover ..  (Read 12141 times)
walter
« on: May 13, 2009, 08:51:03 AM »
i need to remove taillight cover of my EF, how do i can remove it without scrath the cover? i fucket one already trying to remove with hairdryer  :'(
Re: How to remove tail light cover ..
« Reply #1 on: May 13, 2009, 09:54:06 AM »
When I did headlight I place the light on a cookie sheet place in oven at around 200 deg F (95deg C) for about 20 min.
The adhesive will soft enough where you can use a razor blade and seperate the lens.
Then clean all the surfaces and use a clear RTV to glue everthing back together.
I have used a heat gun but I end up disstorting some of the plastic.
walter
« Reply #2 on: May 13, 2009, 03:59:07 PM »
i see, but i means tailight, it's all plastic... ill try , thx!
« Reply #3 on: May 13, 2009, 07:57:50 PM »
Led?
walter
« Reply #4 on: May 13, 2009, 08:31:23 PM »
