Author Topic: Need some help Fuel related  (Read 24936 times)
« on: May 18, 2009, 04:20:46 PM »
So I got my car all put back together, started it up first try. I drove it around for about a mile or so, wasn't building boost. I was trying to figure out where my leak was (my turbo sounds like a supercharger) I turned the key off, came back and the fucker wont start. Checked plug wires, fucking things fell apart. Bought new wires, I have spark. Checked my wiring for the resistor box, and on the harness the left side is positive and the right side is negative (backwards) Yes I have a resistor box. Here is a picture of how it is setup.
Any ideas? I need to get my shit running
« Last Edit: May 18, 2009, 04:27:27 PM by glustic »
Re: Need some help Fuel related
« Reply #1 on: May 18, 2009, 04:38:06 PM »
double check injector wiring.
is the fuel pump priming?
check grounds
I dont know whats going on, I was on the phone with you earlier and it just sounded like you had a boost leak.
how much gas is in the car?
« Reply #2 on: May 18, 2009, 04:47:22 PM »
check grounds
Yes the fuel pump primes. I checked over my resistor box wiring, its exactly like the diagram shows, I cut the yellow/black stripe put all 4 that go into the ecu into the red wire on my resistor box, and then wired each yellow/black stripe wire that goes into the injector clip into each of the 4 black wires on the resistor box.
Has a half a tank of gas. I do still have a boost leak, but now my car wont start
« Last Edit: May 18, 2009, 04:49:09 PM by glustic »
Loserkidwac
« Reply #3 on: May 18, 2009, 04:53:20 PM »
check dizzy timing, I've had cars where it was to retarded and it wouldn't start and just seemed to flood the engine
2002 BMW 530i Sport
1992 Mazda Miata
1998 K2500 454
« Reply #4 on: May 18, 2009, 04:58:50 PM »
I have no injector pulse. The yellow/black wire lights up when key is on and the light tester is grounded. using the other side as a ground (whether it be yellow blue red or brown) it doesnt ground on that side.
I tried switching to the stock ECU to see if it would start and no luck... I have no engine light.
« Last Edit: May 18, 2009, 05:03:37 PM by glustic »
« Reply #5 on: May 18, 2009, 05:04:10 PM »
igniter and/or coil
busted dizzy
« Reply #6 on: May 18, 2009, 05:07:25 PM »
igniter and/or coil
busted dizzy
I have spark.
« Reply #7 on: May 18, 2009, 05:10:04 PM »
igniter and/or coil
busted dizzy
I have spark.
Recheck your connections for your resistor box.
And if you had to splice injector clips in make sure you wired them right.
« Reply #8 on: May 18, 2009, 05:10:44 PM »
ostrich took a shit?
« Reply #9 on: May 18, 2009, 05:12:44 PM »
igniter and/or coil
busted dizzy
I have spark.
I did, all seems fine. I just dont see how my car can start up, I drive it for a mile, turn the key off and blam no fuel.
I had to splice in the clips, they are wired so the yellow/black stripe wire is ground, and the other side positive.
« Reply #10 on: May 18, 2009, 05:16:03 PM »
i know you said half a tank of gas, but could it be out of gas  :?:
i think i remember reading that the pickup on the walbros wasn't long enough or some shit.
don't know if that was with all the walbros or just the xenofaggot ones
I remember seeing the fuel level about where that brace is inside the fuel tank
Its brand new.. I wrote and verified to it a few times, plus the car should start with the stock ecu.
« Reply #11 on: May 18, 2009, 05:16:34 PM »
any blown fuses or fuel relay clicking noise?
« Reply #12 on: May 18, 2009, 05:17:44 PM »
Havent check all the fuses, only the select ones in the engine bay. What other fuse should I check? I was gonna go on all data and pull up which fuses are for what.
schim187
« Reply #13 on: May 18, 2009, 07:11:45 PM »
I had the same problem a while back with my 95 dx...checked the ecu fuse under the hood and it was blown...replaced and started right up
« Reply #14 on: May 18, 2009, 08:36:46 PM »
Word I am planning on checking fuses tomorrow. Will let all you nogs know.
« Reply #15 on: May 19, 2009, 02:25:11 PM »
So, I decided to try and start the car up this morning, and the fucker started right up. All I did was plug in my injectors.. Wtf? Took off dizzy cap, shit looks brand new. Any Ideas?
« Reply #16 on: May 19, 2009, 02:41:26 PM »
Does your inj. harness plugs still have their metal spring locks?
« Reply #17 on: May 19, 2009, 02:45:43 PM »
I don't believe so. Thing is we used a tester to see if the clips would pulse and they didn't yesterday.
BoostForLife
« Reply #18 on: May 19, 2009, 03:17:07 PM »
Check the underdash fuses. There are a few over there that won't let you car start when blown. Just pull them all out one by one and if it's good put it back to where you took it out of. Should only take like 2 mins.
I had a fuse blow there and car also wouldn't start.
« Reply #19 on: May 19, 2009, 03:34:46 PM »
I was going to check the fuses, but like I said my car started up no problem this morning. All I did was plug in the injector harness in.
« Reply #20 on: May 19, 2009, 08:47:10 PM »
yeah ususally your car starts great then a fuse blows and it won't start anymore.
i'd check the fuses. all of them.
Thats the thing man... It started up fine all day long. The fuse cant un-blow it self...
