Author Topic: B16 lsd in LS transmission  (Read 10307 times)
hamburgler
« on: May 19, 2009, 11:16:00 PM »
Is there anything specific I need for this swap?  I will assume I can use the same inner and outer bearings because only the GSR trans has the tapered roller bearings.
Ravage70
Re: B16 lsd in LS transmission
« Reply #1 on: May 19, 2009, 11:34:50 PM »
I will go ahead and say you need the ring gear/fd also
« Reply #2 on: May 19, 2009, 11:59:11 PM »
B16 and LS have the same bolt pattern for the ring gear.
Coming next with be ring gears with dual bolt patterns for  B16/LS or GSR/ITR trannys.
hamburgler
« Reply #3 on: May 20, 2009, 12:15:26 AM »
From the searching I found is that the diffs should swap over if you have a complete b16 transmission and complete LS transmission - both of which I have.
